  • Dual SPST On/On Light Duty Toggle Switch
CLEARANCE Dual SPST On/On Light Duty Toggle Switch
Parts ExpressPart # 060-544
This light duty switch can turn one device on while turning another device off using 2 different voltages.
  • On/off label to let you know temporary device is on
  • Sturdy metal toggle
  • Minimum Order 5 pcs
CLEARANCE $1.19
Save $0.80 (40%)
13 In Stock
We'll send you an email when Dual SPST On/On Light Duty Toggle Switch is back in stock or available for preorder.
This light duty toggle switch uses simple on/on switching. Contacts 1 and 2 connect when the switch is in the up position. Contacts 3 and 4 connect when the switch is in the down position. Only one device will be on at a time. This enables you to bring two different voltages in to power two different devices with one switch. Turn on a temporary device while disconnecting the main device.
Specifications: • Current rating: 4A @ 125 VAC, 2A @ 250 VAC • Contacts: 4 • Shaft diameter: 12.2 mm (31/64").
Part Number060-544
UPC844632075452
Weight0.01
CircuitDPDT
Contact Rating @ Voltage4A 125 VAC
IlluminationNon-Illuminated
