  • Dual IR Extender with 16 ft Cord and 6 ft USB Cable
CLEARANCE Dual IR Extender with 16 ft Cord and 6 ft USB Cable
Parts ExpressPart # 180-649
Are you tired of having to step out of your room or open your closet door every time you want to change the channel or adjust the volume on your TV? Say goodbye to those inconveniences with our 16 ft. IR extender with dual IR emitters.
  • 3.5 mm 16 ft. cable can be extended if needed to reach your equipment room
  • Dual IR extenders for two components that might receive the same codes
  • USB cable plugs directly into most smart TVs or any powered USB port for convenience
CLEARANCE $6.24
Save $13.75 (69%)
42 In Stock
We'll send you an email when Dual IR Extender with 16 ft Cord and 6 ft USB Cable is back in stock or available for preorder.
With this 16 ft. IR extension, you're now able to send your IR remote signal to another room, inside a closet, or even behind a wall. No more clutter or limitations! This IR extender is here to make your home theater room cleaner looking and more comfortable. The USB connector plugs directly into most smart TVs or other USB-A ports for power.
The 16 ft. length of this extender gives you the flexibility to position A/V sources wherever you want, while still having complete control from the convenience of your home theater chair. Whether you need to control your audio system, cable box, or any other IR-controlled device, this extender has got you covered.
But what sets this extender apart from others on the market are the dual IR emitters. These emitters ensure that the signal is not only transmitted accurately but also reaches multiple devices in the same location. So, you can control your TV in one room and your sound system and cable box in another, all with a single universal remote. Two emitters enable you to isolate the IR signals if needed.
Installation is a breeze too! Simply put the IR target next to your display (TV or video screen) and place the emitters on or near the devices you want to control. Thanks to its discreet design, you can easily hide the thin wire under the carpet or behind baseboards. You're also able to extend the 16 ft. length with another 3.5 mm mono extension cable if needed.
So, why settle for eye sore A/V components in your home theater room when your able to control them discretely with our 16 ft. IR extender with dual IR emitters? Say goodbye to annoying clutter around your TV or video screen and hello to hidden control of your video and audio sources. Upgrade your remote experience today and make your home theater viewing a whole lot neater!
Part Number180-649
UPC848864074542
Weight0.17
