  • Dual Banana Plugs with Gold Terminals 1 Pair -Black, Red
Parts ExpressPart # 091-3638
Dual banana plugs are for use with test equipment including volt meters and multimeters, frequency generators and counters, and audio devices using banana jacks or binding posts with standard 0.75" center to center spacing.
  • Gold plated for years of reliable service
  • Screw type for easy termination
  • No crimping or soldering required
  • Accepts up to 12AWG wire
Your Price: $3.39
Save $2.60 (43%)
We'll send you an email when Dual Banana Plugs with Gold Terminals 1 Pair -Black, Red is back in stock or available for preorder.
Dual banana plugs have been widely used in the electronics industry since early in the last century. Commonly used with test equipment, dual banana plugs are designed with industry standard 0.75" center to center post spacing. A plastic tag molded to one side of the connector is marked GND so the user can quickly identify the negative side of the connector. An integrated strain relief on one side of the connector holds the cable securely in place. Accepts up to 12 AWG cable and attaches with screw terminals so soldering is not necessary. Gold plated brass contacts will provide a lifetime of use free of oxidation.
Part Number091-3638
UPC848864079776
Unit of MeasurePairs
Contact PlatingGold
Style / TypeDual
