  • Denon DP450USB HiFi Belt Driven Turntable Black
CLEARANCE Denon DP450USB HiFi Belt Driven Turntable Black
DenonPart # 245-4040
Model: DP450USB
Equipped with a pre-mounted MM cartridge, built-in phono preamp, and a meticulously engineered tonearm featuring auto lift and playback stop, the Denon DP450USB brings out the intricate details in your cherished albums.
  • USB one-touch recording to MP3 or WAV files
  • Semi-automatic operation
  • Moving magnet cartridge
  • Reference output
  • Built-in phono preamp
CLEARANCE $749.00
3 In Stock
We'll send you an email when Denon DP450USB HiFi Belt Driven Turntable Black is back in stock or available for preorder.
Equipped with a pre-mounted MM cartridge, built-in phono preamp, and a meticulously engineered tonearm featuring auto lift and playback stop, the Denon DP450USB brings out the intricate details in your cherished albums. The integrated auto sensor precisely controls the platter, supporting playback at 33 1/3, 45, and 78 rpm. The exclusive removable dust cover serves a dual purpose as a display stand for album covers, adding a touch of functionality and style to your setup.
The built-in phono equalizer of the DenonDP450USB establishes a spacious, immersive sound stage that revitalizes your vinyl collection while preserving the authenticity of the original recording. You can connect it directly to a mini component or integrated amp without a phono terminal, ensuring seamless integration and hassle-free use.
Unboxing and setting up the DP450USB is a quick and straightforward process, taking just minutes for both novice and seasoned vinyl enthusiasts. Simply plug the DP450USB into your preferred amplifier or system, and you can instantly re-establish a connection with your vinyl collection—it's that easy.
The incorporated USB-A output facilitates convenient one-touch recording of your cherished vinyl records onto a USB drive in MP3 or WAV format files. Whether you prefer playing your albums on the DP-450USB or taking them with you, you can enjoy the renowned Denon sound wherever you go.
The removable dust cover of the DP450USB boasts a modern design, enhancing the overall aesthetic while eliminating vibration issues that can impact music quality with attached covers. Additionally, it serves a dual purpose as a display stand for your album cover. Simply place the dust cover upright on the included base, allowing you to showcase your album proudly to your friends.
Features
  • DC Belt drive motor
  • Static balance tonearm
  • Automatic operation
  • Speeds: 33-⅓ & 45 RPM
  • Wow & flutter: 0.10% WRMS
  • Built-in switchable photo EQ
  • Stylus version DSN-85
  • USB input/output for direct recording (software included)
  • Rated output: 2.5 mV/1kHz
  • Frequency Range: 20 Hz - 20 kHz
  • S/N Ratio: 62 dB
  • Maximum dimensions: 16.2" W x 13.7" D x 5.2" H
  • Weight: 12.4 lbs
BrandDenon
ModelDP450USB
Part Number245-4040
UPC883795004503
Weight16.95
Drive TypeBelt Drive
