  • Denon DP400WT Belt Driven HiFi Turntable White
CLEARANCE Denon DP400WT Belt Driven HiFi Turntable White
DenonPart # 245-4046
Model: DP400WT
Equipped with a pre-mounted MM cartridge, built-in phono preamp, and a meticulously engineered tonearm featuring auto lift and playback stop, the Denon DP-400 brings out the intricate details in your cherished albums.
  • Reference output
  • Semi-automatic operation
  • Moving magnet cartridge
  • Built-in phono preamp
  • White color
CLEARANCE $549.00
2 In Stock
We'll send you an email when Denon DP400WT Belt Driven HiFi Turntable White is back in stock or available for preorder.
Equipped with a pre-mounted MM cartridge, built-in phono preamp, and a meticulously engineered tonearm featuring auto lift and playback stop, the Denon DP-400 brings out the intricate details in your cherished albums. The integrated auto sensor precisely controls the platter, supporting playback at 33 1/3, 45, and 78 rpm. The exclusive removable dust cover serves a dual purpose as a display stand for album covers, adding a touch of functionality and style to your setup.
The built-in phono equalizer of the Denon DP-400 establishes a spacious, immersive sound stage that revitalizes your vinyl collection while preserving the authenticity of the original recording. You can connect it directly to a mini component or integrated amp without a phono terminal, ensuring seamless integration and hassle-free use.
Unboxing and setting up the DP-400 is a quick and straightforward process, taking just minutes for both novice and seasoned vinyl enthusiasts. Simply plug the DP-400 into your preferred amplifier or system, and you can instantly re-establish a connection with your vinyl collection—it's that easy.
The removable dust cover of the DP-400 boasts a modern design, enhancing the overall aesthetic while eliminating vibration issues that can impact music quality with attached covers. Additionally, it serves a dual purpose as a display stand for your album cover. Simply place the dust cover upright on the included base, allowing you to showcase your album proudly to your friends.
Features
  • DC Belt drive motor
  • Static balance tonearm
  • Automatic operation
  • Speeds: 33-⅓ & 45 RPM
  • Wow & flutter: 0.10% WRMS
  • Built-in switchable photo EQ
  • Stylus version DSN-85
  • Rated output: 2.5 mV/1kHz
  • Frequency Range: 20 Hz - 20 kHz
  • S/N Ratio: 62 dB
  • Maximum dimensions: 16.2" W x 13.7" D x 5.2" H
  • Weight: 12.4 lbs
BrandDenon
ModelDP400WT
Part Number245-4046
UPC883795004756
Weight16.8
Drive TypeBelt Drive
