  • Denon DN350UI Rack Mount Media Player with FM Tuner Internet Radio and Bluetooth
CLEARANCE Denon DN350UI Rack Mount Media Player with FM Tuner Internet Radio and Bluetooth
Denon ProfessionalPart # 245-3651
Model: DN350UI
6 Questions, 9 Answers or
The Denon DN-350UI rack mount internet radio and media player features complete network functionality via wired Ethernet or wireless LAN, balanced audio outputs, and MP3, WAV and WMA file playback from USB media. The DN-350UI can also be paired with Bluetooth devices for wireless audio streaming. Access thousands of Internet radio stations and podcasts, terrestial FM radio, and even stream your favorite music utilizing Spotify Connect.
  • Internet radio and FM tuner with 30 station presets
  • Enabled with Spotify Connect for direct music streaming
  • Network-ready via Ethernet port
  • Play files from USB media and Bluetooth devices
  • Balanced XLR and unbalanced RCA outputs
  • Digital coax and optical outputs
We'll send you an email when Denon DN350UI Rack Mount Media Player with FM Tuner Internet Radio and Bluetooth is back in stock or available for preorder.
The DN-350UI Internet Radio and Media Player completes any commercial or home audio system with the options needed for ease-of-use and convenience. Not only featuring complete network operability via wired Ethernet or wireless LAN, balanced audio outputs, and the ability to play mp3, WAV and WMA files from USB media, this 1RU package can also be paired with Bluetooth devices for added flexibilty. Access thousands of Internet radio stations and podcasts, terrestial FM radio, and even stream your favorite music utilizing Spotify Connect.
Frequency response: 20-20,000 Hz
SNR: 97 dB
THD: 0.003%
Radio frequency range: 87.5-108 MHz (FM)
FM station memory: 30 stations
Bluetooth version: Version 4.0 (A2DP, AVRCP profile)
Bluetooth range: Up to 100 ft.
Wireless transmission: Wi-Fi 5 GHz 802.11n 40 MHz RF performance
RF frequency: 2.4-2.4835 GHz; 5.15-5.875 GHz
Output connections: 2 x balanced XLR, stereo RCA unbalanced, RCA digital coax / optical, digital TOSLINK, Ethernet, USB Type-B for file playback, USB Type-B for firmware
Output level: 1.3 Vrms XLR, 2.0 Vrms RCA
File format playback: MP3, WAV, WMA, FAT16/32 files
Maximum size for connected drive: 128 GB
Power connection: Standard IEC
Power: 110~240 VAC, 50/60 Hz
Power consumption: 15 watts
Dimensions: 16.9" W x 7.9" D x 1.72" H
BrandDenon Professional
ModelDN350UI
Part Number245-3651
UPC694318023235
Weight8.85
