  • Denon DN-300Z Rack Mount CD / SD / USB / Bluetooth / AM / FM Media Player
CLEARANCE Denon DN-300Z Rack Mount CD / SD / USB / Bluetooth / AM / FM Media Player
Denon ProfessionalPart # 245-3644
Model: DN-300Z
The DN-300Z multimedia player from Denon Pro truly puts the "multi" in multimedia! Perfect for front-of-house, education, music and rehearsal studios, houses of worship, restaurants and more, the DN-300Z handles everything from CDs to Bluetooth to solid state media and broadcast radio without breaking a sweat.
  • Fast loading slot-in CD mechanism
  • Front panel USB / HDD / SD / SDHC ports and AUX in
  • Bluetooth playback for mobile devices
  • Balanced XLR and unbalanced RCA outputs
We'll send you an email when Denon DN-300Z Rack Mount CD / SD / USB / Bluetooth / AM / FM Media Player is back in stock or available for preorder.
Denon's DN-300Z rackmount CD / SD / USB / Bluetooth / AM / FM Media Player provides virtually any kind of playback capability you may need in your next system install or upgrade. Balanced and unbalanced audio outputs make it easy to integrate into any system, and there is even a 3.5 mm AUX in for portable media devices. Simple to operate, you’ll find the purity of its audio performance is truly remarkable at its modest price point - giving you a rugged, no-compromise playback solution that occupies a mere 1U of space. An IR remote is included.
It really does expect the unexpected. Go ahead, throw anything you want at it: front-loading media slots (CD w/single-play mode, USB, SD/SDHC) deliver intuitive playback of today’s familiar mass-storage mediums. Or, go wireless with long-range Bluetooth audio connectivity (up to 100 feet) and instant recall of up to 8 devices such as smartphones and tablets. With support for CD-DA, MP3, WAV, and AAC file formats, the DN-300Z is the master-of-all-trades player that excels when the unpredictable occurs. The 300Z features both RCA audio outputs and balanced XLR outputs. The balanced outputs are a much-needed feature in the professional/commercial sector, since they enable long connection cable runs without any increase in stray noise pickup. The selectable Power-On-Play mode automatically plays USB, SD or CD tracks when powered up — simply turn it on. And, the AM/FM tuner has a dedicated audio out for multi-zone use.
The front panel's backlit LCD screen provides at-a-glance status of playback modes and content, providing clear readouts to even the most novice user. Designed to adapt to any scenario, switching formats on the fly has never been easier. Media categories and their respective controls are grouped together so users will never have to wrestle with deep menus or use the instruction manual to perform basic functions. Direct access to CD tracks, global transport controls (play/pause/search), and a rotary-push encoder translate to fast, hands-on command when you need to get to your content.
An IEC-weighted AC power port means space-saving connection to power sources—no bulky transformers or “wall warts” required. When installed into a client’s rack, the DN-300Z provides the capability, reliability, and versatility to tackle any playback task, from one-off requests to rehearsed program material, in an intuitive, tidy package.
The DN-300Z media player expects the unexpected. But you demand it.
Specifications: • Frequency response: 20 - 20,000 Hz • Compatible CD formats: CD-DA, CD-ROM (ISO9660), CD-R, MP3-CD • Compatible USB/SD/SDHC file systems: FAT16, FAT32 • Supported WAV format: extension - WAV • Bitrate: 16-bit • Sampling frequency: 44.1 kHz • Supported AAC format: extension: M4A • Compression method: AAC-LA • Bitrate: 32 to 320 kbps and VBR • Sampling frequency: 44.1 kHz • Signal to noise ratio: > 95 dB (A-weighted) • THD: < 0.01% • Channel separation: > 80 dB • Dynamic range: > 85 dB • Supply voltage: 120 VAC, 60 Hz • Weight: 7.94 lbs. (3.6 kg) • Dimensions (with rack ears): 19.00" x 13.66" x 1.73" (483 x 347 x 44 mm).
BrandDenon Professional
ModelDN-300Z
Part Number245-3644
UPC694318016817
Weight12.35
