  • Denon DM-41SBK Micro Hi-Fi Stereo System with CD Player
DenonPart # 245-4026
Model: DM-41SBK
The Denon D‑M41 is a compact, full-featured mini stereo system that combines a CD player, FM tuner, Bluetooth streaming, and a stereo amplifier into a single, elegant unit—perfectly designed for small spaces like bedrooms or offices. With its “Simple & Straight” circuit design, including triple noise reduction, it captures clear, authentic Denon sound in a stylish, space-saving package. It delivers 30 W per channel (at 6 Ω), drives the included SC‑M41 speakers, and is built with short signal paths to preserve audio purity.
  • Simple & Straight circuit layout preserves audio signal purity
  • CD player, FM tuner, and two optical inputs support multiple sources
  • 2 × 30 W discrete analog output with subwoofer pre-out
  • Bluetooth connectivity with independent OFF switch to reduce interference
  • Triple Noise Reduction Design minimizes distortion across circuits
  • Matching SC-M41 speakers designed for rich bass and clean treble
  • Compact size with premium styling inspired by Denon’s New Era series
Your Price: $630.00
We'll send you an email when Denon DM-41SBK Micro Hi-Fi Stereo System with CD Player is back in stock or available for preorder.
Order in the next 10 hr 29 min to ship today. Details
A Mint Hi-Fi System for Maximum Enjoyment
An all new and improved version of Denon's famous M-Series sound.
Best Match
The SC-M41 speaker system reflects Denon’s tradition of hi-fi craftsmanship
Distortion is minimized to improve the signal-to-noise ratio, resulting in smoother and more dynamic audio
Sound Purity
This popular M series delivers high-quality sound built on a simple and straightforward design philosophy
A Compact, Full-Featured System
Exceptional Sound Design
The amplifier circuit outputs 2x30W, delivering enough power for the SC-M41 speakers or other widely used models.
Improve your TV Sound
Use an optical cable to connect your TV, game console, or media player to the D-M41 and enhance your entertainment with improved audio.
Bluetooth Streaming
Denon’s well-known M series emphasizes sound quality through a “simple & straight” approach, with a layout and chassis that preserve sonic accuracy.
Simple & Straight
Compact at 8.27" wide and 12.2" deep, it fits effortlessly on a bookshelf, desk, or in any room where space is limited.
Premium Sound, Compact Size
Lorem Ipsum is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since the 1500s, when an unknown printer took a galley of type and scrambled it to make a type specimen book.
Sonic Innovation
For the Past 110 Years
For over a century, Denon has developed innovative audio products that uncover extraordinary detail. Inspired by their Japanese heritage, each piece is meticulously hand-tuned by their sound master to deliver a unique listening experience. Get ready to hear your music in a whole new way.
Technical Information
  • Power output: 30 W+30 W (6 ohms, 1 kHz)
  • Input / Output Terminal:
    -1 set of analogue inputs
    -2 sets of digital inputs (optical)
    -MONO output for subwoofer
    -Headphone
  • Function:
    -Tone control (Bass, Treble)
    -SDB (Super Dynamic Bass)
    -Source direct function
    -Timer (once, everyday, sleep)
    -CD playback repeat, random mode
  • Tuner:
    -DAB Band III 174 MHz – 240 MHz (DAB version only)
    -FM 87.50 MHz – 108.00 MHz
    -Presets x 40
    -RDS
    -Radio text
    Bluetooth
  • Compatible Bluetooth Profiles: A2DP/AVRCP
  • Supported Codecs: AAC/SBC
  • Multi-pairing: 8
    General
  • Power supply: AC 230 V, 50/60Hz
  • Power consumption: 70 W (Standby: 0.3 W)
  • Dimensions (W x H x D): 8.27" x 4.53" x  12.2"
  • Weight: 8.82 lbs.
  • SC-M41
  • Type: 2-way speaker
  • Drivers: 120 mm woofer, 25 mm soft dome tweeter
  • Frequency response: 45 Hz - 40 kHz
  • Max power: 60 W (IEC) 120W (PEAK)
  • Impedance: 6 ohms
  • Dimensions (W x H x D): 5.71" x 9.37" x 9.21"
  • Weight: 9.3 lbs.
BrandDenon
ModelDM-41SBK
Part Number245-4026
UPC883795004244
Weight32.4
