  • Shadow Mounts TM55 Slim TV Wall Mount with Tilt 23"-55" 175 lb. Capacity
CLEARANCE Shadow Mounts TM55 Slim TV Wall Mount with Tilt 23"-55" 175 lb. Capacity
Shadow MountsPart # 182-323
Model: TM55
Shadow Mounts TV mounts place the focus on your flat panel television -- not the hardware. The Shadow Mounts TM55's inconspicuous flat black finish makes the TV mounting system virtually disappear behind the television display.
  • Easy installation and adjustment with innovative mounting hole design
  • Tilt detents at 0, 5, 10, 12, and 15°
  • When mounted, TV is only 1.4" from the wall
  • 175 lb. capacity
  • Mount TVs from 23" ~ 55"
CLEARANCE $17.43
MSRP: $28.99
Save $11.56 (40%)
5 In Stock
We'll send you an email when Shadow Mounts TM55 Slim TV Wall Mount with Tilt 23"-55" 175 lb. Capacity is back in stock or available for preorder.
The heavy-duty Shadow Mounts TM55 is manufactured from solid steel, and provides you with peace of mind from knowing your HDTV investment is held securely in place for years to come. Installation and adjustment are easier with the TM55's innovative mounting hole design that makes it easy to fine tune the mount to level once attached to the wall.
Brackets hold the TV firmly into place and can be removed by pulling the release cables. Tilt the TV to its most desirable angle with the 5, 10, 12, and 15° detents. The ultimate feature of the TM55, however, is the low-profile design that holds the monitor a mere 1.4" from the wall when the TV is in the flat position.
The Shadow Mounts TM55 is compatible with 23" ~ 55" televisions that utilize a VESA 400 mm x 400 mm bolt pattern. Note: Consult your TV owner's manual for VESA sizing information.
Specifications: • Mounting plate width: 17.72" (450 mm) • Mounting plate height: 5.197" (132 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 16.73" (425 mm) • Tilt adjustment: 0, 5, 10, 12, 15° • Minimum mount to wall distance: 1.4" (36 mm) • Mounting width supported: 50-410 mm • Mounting height supported: 50-400 mm • Supported VESA sizes: up to 400 x 400 • Maximum weight capacity: 175 lbs. (80 kg).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelTM55
Part Number182-323
UPC848791000577
Weight5.05
Mount StyleWall Mount
Mount TypeTilting
TV Capacity49" to 70"
