Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for SubwoofersInstalling a second audio zone or putting a subwoofer exactly where you want it can be a challenge if you can't run the proper cables. Renters and owners of finished homes may find in-wall cabling impossible.
The Dayton Audio Sub-Link™ Wireless Audio System solves wiring dilemmas, quickly and easily. Place your subwoofer in the location that provides optimal sound without worrying about a cable. Or, add a subwoofer to the rear of your listening space to spread out the low frequency effects of your favorite movies. Check the prices on long subwoofer cables, and you might find out that in addition to being more convenient, the Sub-Link is also more affordable!
For users hoping to add stereo zone capability to an existing A/V installation, the Dayton Audio Sub-Link Wireless Audio System extends the options and uses of your primary audio system. Use the Sub-Link to add powered speakers or passive speakers running off a local amplifier to your patio, pool area, or anywhere you'd like to enjoy music away from your primary A/V system. Connect the Sub-Link to your PC, TV, or streaming media player and send a signal to any stereo in the house.
Dayton Audio's Sub-Link Wireless Audio System includes one transmitter and one receiver, two 22" 3.5 mm stereo male to stereo male RCA adapter cables, two 22" 3.5 mm stereo male 3.5 mm to mono male RCA adapter cables, two 30" USB-A male to micro USB-B male charging cables, and two USB 5V DC, 2A power adapters.
Specifications: • Transmitter / Receiver operating voltage: 5V DC, 1A • RF frequency band: 2.404 to 2.467 GHz • Modulation: GFSK • Working distance: 12 meters (40 feet; unobstructed line-of-sight) • Transmitter power: ≤ 10 dBm • Transmitter input sensitivity: 700 mV @ 1% THD • Receiver sensitivity: -85 dBm • Frequency response: 15 to 20,000 Hz +1/-3 dB • Delay time: <25ms • THD+N: -60 dB @ 1 kHz. • Dimensions per unit: 2-5/8/" L x 2" W x 1/2" H.
Pairing: These units come paired from the factory, but if they become un-paired, follow these steps. Press and hold the button on one unit. Then, press and release the button on the second unit. Finally, release the button on the first unit and your transmitter and receiver will be paired.
Note: This product uses USB for power purposes only. This product does not connect to a computer for data purposes and will not act as a sound card for the transfer of audio.
