  • Shadow Mounts PM1020 Projector Mount with 20"-29" Extension
CLEARANCE Shadow Mounts PM1020 Projector Mount with 20"-29" Extension
Shadow MountsPart # 182-386
Model: PM1020
Shadow Mounts place the focus on the performance of the equipment—not the mount. For vaulted ceilings, select the PM1020 for an adjustable ceiling to projector distance of 20.5" to 29.1".
  • Universal style fits most projectors
  • Flat black finish disappears on the ceiling
  • Rigid extruded aluminum construction
  • ±15° tilt and ±180° of swivel adjustment
  • Instructions and hardware included
CLEARANCE $22.73
Save $69.26 (75%)
7 In Stock
We'll send you an email when Shadow Mounts PM1020 Projector Mount with 20"-29" Extension is back in stock or available for preorder.
Order in the next 15 hr 6 min to ship today. Details
Shadow Mounts place the focus on the performance of the equipment—not the mount. Flat black paint is used to reduce the occurrence of distractions generated by a shiny finish. Extruded aluminum construction provides extreme rigidity with modern styling, and the universal nature of the mount designs allows them to be configured to accommodate three of four mounting holes for compatibility with nearly every projector on the market. 30° of tilt and 360° of swivel allow for easy adjustments and quick setup time. Instructions and mounting hardware are included. For vaulted ceilings, select the PM1020 for an adjustable ceiling to projector distance of 20.5" to 29.1".
Dimensions and Specifications: • Mounting arm span: 7.2" (182 mm) • Projector to ceiling distance: 20.5"-29.1" (520-740 mm) • Tilt adjustment: ±15° • Swivel adjustment: ±180° • Maximum weight capacity: 33 lbs. (15 kg).
BrandShadow Mounts
ModelPM1020
Part Number182-386
UPC844632067907
Weight4.19
