  • Shadow Mounts HD3260ARM Heavy-Duty Full-Motion TV Wall Mount 32"-90"
Shadow MountsPart # 182-361
Model: HD3260ARM
There simply is no better mount for integrating HDTVs into custom applications than the Shadow Mounts HD3260ARM.
  • Great for placing TVs in the corner of a room
  • Designed for TVs 32" to 90"
  • Durable steel construction
  • Extends up to 20" from a wall
  • ±45° of left to right swivel and ±15° of tilt
  • Features patented RailClip™ function
Shadow Mounts AM5516 Articulating TV Wall Mount 32"-80"
Price: $68.98Part # 182-327
See all items in TV Mounts & Brackets
Your Price: $89.98
MSRP: $103.99
Save $14.01 (13%)
Quantity:Qty: 1-3 $89.98/ea
Quantity:Qty: 4+ $82.58/ea
We'll send you an email when Shadow Mounts HD3260ARM Heavy-Duty Full-Motion TV Wall Mount 32"-90" is back in stock or available for preorder.
The Shadow Mounts HD3260ARM features scissor arms creating the ultimate support for your HDTV (up to 90" or 150 lbs.) while offering up to 20" of extension from the wall. Additionally, this mount makes corner and off-axis mounting simple and easy with ± 45° of left to right swivel. With ± 15° of tilt, you aren't locked in to a particular mounting height—perfect for custom applications such as mounting your HDTV above a fireplace. 2 mm cold-rolled steel is used throughout for maximum durability. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
Specifications: • Mounting plate dimensions: 19.7" W x 9.6" H • TV plate dimensions: 32" W x 9.4" H • TV bracket dimensions: 1.375" W x 21" H • Swivel adjustment: ± 45° • Tilt adjustment: ± 15° • Distance from wall: Adjustable from 4.5" to 20" • VESA sizes supported: 50 mm W x 50 mm H up to 700 mm W x 400 mm H • Maximum weight capacity: 150 lbs.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelHD3260ARM
Part Number182-361
UPC844632094996
Weight31.85
Mount StyleWall Mount
Mount TypeFull-Motion Articulating
TV Capacity75" and larger
