  • Dayton Audio ST602-4 60W Titanium Bullet Tweeter with Square Frame Pair
CLEARANCE Dayton Audio ST602-4 60W Titanium Bullet Tweeter with Square Frame Pair
Dayton AudioPart # 275-402
Model: ST602-4
The ST602-4 from Dayton Audio was designed to articulate and reinforce the high-frequency output of any professional loudspeaker. With a great price-to-performance ratio, you would be hard-pressed to find a better driver to keep on hand!
  • High sensitivity output designed for pro audio duty
  • 1" titanium diaphragm for a detailed response
  • Compact size to fit in the tightest spaces for smaller boxes
  • 5,100Hz crossover point is perfect for 3-way designs
  • Easily adds detail to any existing system
We'll send you an email when Dayton Audio ST602-4 60W Titanium Bullet Tweeter with Square Frame Pair is back in stock or available for preorder.
Fantastic high-frequency performance, even better value
Key Specs:
  • Power Handling (RMS): 30 Watts
  • Power Handling (MAX): 60 Watts
  • Impedance: 4 Ω
  • Frequency Response: 5100Hz - 20kHz
  • Sensitivity: 106 dB 2.83V/1m
  • Voice Coil Diameter: 1"
Frequency Response & Impedance
The Dayton Audio ST602-4 is a supertweeter that can keep up with many midrange drivers. By taking advantage of its high-frequency response, you can add air and clarity to any PA system!
High Sensitivity
The Dayton Audio ST602-4 has a high sensitivity to keep up with the demands of live audio. An output sensitivity of 106dB means the ST602-4 can add detail to even the most sensitive PA cabinets. When installed, the high-frequency output provides a clear and airy experience for every audience member in the crowd!
High Value
Dayton Audio created the ST602-4 to provide a reliable replacement option with a response that comfortably integrates with existing designs, all at a great value. These features also put the speaker designer at an advantage, allowing for a large variety of possible combinations when choosing drivers for their own projects!
We've Got Your Back
Learn More
Shop all Dayton Audio HF Drivers
PRO NEO-8
  • Exit Diameter: 1"
  • Frequency Response: 2.6kHz - 20kHz
Shop Now
PRO-8
  • Exit Diameter: 1"
  • Frequency Response: 2.5kHz - 20kHz
Shop Now
ST601-4
  • Exit Diameter: 1"
  • Frequency Response: 5.2kHz - 20kHz
Shop Now
ST603-4
  • Exit Diameter: 1"
  • Frequency Response: 6.9kHz - 20kHz
Shop Now
ModelST602-4
Part Number275-402
UPC848791008658
Unit of MeasurePairs
Weight1.5
Diaphragm MaterialAluminum
Power Handling (RMS)60 Watts
