  • Dayton Audio SPA-F Subwoofer Plate Amplifier Mounting Frame for SPA250DSP and SPA500DSP
CLEARANCE Dayton Audio SPA-F Subwoofer Plate Amplifier Mounting Frame for SPA250DSP and SPA500DSP
Dayton AudioPart # 300-8011
Model: SPA-F
Dayton Audio's SPA-F mounting frame allow you to easily install either the SPA250DSP or SPA500DSP plate amplifier to the outside of your subwoofer enclosure without cutting a large hole which could compromise the structural integrity of your subwoofer enclosure. Just screw the frame to your enclosure and mount the amplifier.
  • Structurally sound 16 gauge steel provides a rigid mounting point
  • Concealed mounting for clean and neat installation
  • Adequate venting for cool amplifier operation
  • Shallow 55 mm mounting depth
We'll send you an email when Dayton Audio SPA-F Subwoofer Plate Amplifier Mounting Frame for SPA250DSP and SPA500DSP is back in stock or available for preorder.
The Dayton Audio SPA-F mounting frame makes it easy to add an SPA250DSP or SPA500DSP subwoofer amplifier to any existing subwoofer without cutting a hole in the enclosure. Constructed from rigid 16 gauge steel the SPA-F includes vents at the top and bottom allowing ample airflow to promote thermal convection to keep the amplifier cool – hot air escapes out the vents in the top, which pulls cool air in the bottom. Foam gaskets on all contact surfaces ensure no vibration or rattles once installed. With the SPA-F adding an amplifier to a subwoofer is easier than ever, all you need is a screwdriver.
Compatible for use only with the Dayton Audio SPA250DSP or SPA500DSP .
Dimensions: 10.25" H x 7.25" W x 2.125" D
ModelSPA-F
Part Number300-8011
UPC848791004728
Weight1.75
