  • Dayton Audio SA230 230W Subwoofer Amplifier
CLEARANCE Dayton Audio SA230 230W Subwoofer Amplifier
Dayton AudioPart # 300-813
Model: SA230
The Dayton Audio SA230 subwoofer amplifier offers its owner the freedom to use a stand-alone, high quality amplifier to operate a subwoofer speaker system.
  • Heavy-duty steel chassis with black brushed aluminum faceplate
  • Mono Class AB output stage for solid, well defined output
  • Low-level, high-level, and LFE inputs
  • Manual, auto, or triggered on/off modes for integration into any automated system
  • 18 dB/octave low pass filter
  • Selectable bass boost
  • Adjustable phase, gain, and crossover
4-Pin Vacuum Tube Socket Gold Plated Ceramic for 300B 811 2A3
Price: $11.98Part # 055-530
See all items in Subwoofer Amplifiers
We'll send you an email when Dayton Audio SA230 230W Subwoofer Amplifier is back in stock or available for preorder.
Dayton Audio's SA230 subwoofer amplifier delivers all of the clean, solid power required to drive small-to-medium sized subwoofer speaker systems. Its tabletop design is compatible with many other popular electronic devices and different styles of multimedia furniture. The SA230 is engineered to provide high fidelity subwoofer amplification and is tailored for home audio and home theater audio systems. Its variable gain, bass boost, crossover frequency, and phase adjustment guarantee perfect integration with any audio system in any listening environment. Short circuit and thermal protection built-in.
Specifications: • Rated power output (1% THD): 156 watts into 8 ohms, 233 watts into 4 ohms • Signal to noise ratio: 85 dB A-weighted • Input impedance: 12K ohms • Input sensitivity: 75 mV • Gain: 0 dB to +10 dB • Bass boost: 25 Hz to 50 Hz • Low pass adjustment: 40 Hz to 180 Hz @ 18 dB/octave • Phase adjustment: 0° to 180° • Dimensions: 17-1/4" W x 3-3/4" H x 13-7/8" D • Power requirements: 120/230 VAC, 50/60 Hz • Stand-by power rating: 120V 0.82W • Weight: 21.05 lbs.
With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise. We stand behind our products and our warranty is a demonstration of our commitment to quality and reliability.
ModelSA230
Part Number300-813
UPC844632089572
Weight21.05
Power (RMS/Channel 8 ohms)101 - 250 Watts
Weight Range10 to 19 lbs.
