  • Dayton Audio MK602X 5.1 Home Theater Bundle with 12" Subwoofer
CLEARANCE Dayton Audio MK602X 5.1 Home Theater Bundle with 12" Subwoofer
Dayton AudioPart # 300-648
1 Question, 2 Answers or
Enjoy true 5.1 channel surround sound with this timbre-matched speaker system, all you need is a home theater receiver. Every speaker in this system is designed in conjunction with one another to match both aesthetically and sonically. Featured in this package are the Dayton Audio MK602X bookshelf speakers as the front channels, MK402X for your rear channels, the MK442 center channel, and Rounding out the bottom end is our 12" powered subwoofer that is perfect for medium to large sized rooms. Learn more about each speaker included in this package below.
  • MK602X bookshelf speakers perfect for use as front and rear channels
  • MK442 center channel adds clarity and detail to dialogue for TV and movies
  • MK402X bookshelf speakers add excitement and depth to rear channels
  • Subwoofer has a downward-firing flared port design for clean, powerful bass
  • LFE cable and speaker wire sold separately
Dayton Audio MK602X 6-1/2 2-Way Bookshelf Speaker Pair
Dayton Audio has created the MK602X with extended bass response and clarity in mind. The high-excursion driver used in this cabinet makes it easy for this speaker to play deeper without distorting at the crossover point, and the soft dome tweeter adds detail and air without being fatiguing. This combination of drivers is perfect for movie marathons, and the woven glass-fiber cone is a great detail that fits in with any décor
  • Woofers: 6-1/2" woven glass-fiber cone with 4-layer coil
  • Tweeter: 1" soft dome tweeter
  • Power Handling: 60 watts RMS/120 watts max
  • Impedance: 4 Ohms
  • Frequency Response: 45-20,000Hz
  • Sensitivity: 87db 1W/1m
  • Dimensions: 12.625" H x 7.825" W x 8.825" D
Dayton Audio MK402X 4" 2-Way Bookshelf Speaker Pair
The MK402X speakers offer incredible sound quality in an almost unbelievable size. The drivers used in this design play a large role in this small speaker. The 4" woofer is easily able to play to 60 Hz and still play into the vocal range impressively. The 3/4" tweeter is capable of producing effortless high frequencies with a wide dispersion. These two drivers, paired with our simple yet effective crossover, create a soundstage that is sure to awe even the harshest of critics.
  • Woofer: 4" high excursion driver with a treated paper cone
  • Tweeter: 3/4" soft dome
  • Power handling: 40 watts RMS/80 watts max
  • Impedance: 4 ohms
  • Frequency response: 60 to 20,000 Hz
  • Sensitivity: 84 dB 1W/1m
  • Dimensions: 9.5" H x 5.75" W x 6.625" D
Dayton Audio MK442 Dual 4" 2-Way Center Channel Speaker
The impressive sound quality offered by the Dayton Audio MK442 center channel speaker is awe-inspiring. The MK442 is designed to complement the Dayton Audio MK402X bookshelf speakers in a multichannel home theater system. It is able to reproduce frequencies as low as 60 Hz, and offers a natural sound with excellent sonic detail. The 3/4" soft dome tweeter paired with two 4" treated-paper cone woofers is a pairing made in audio heaven.
  • Woofer: 2x 4" treated-paper cones with 4-layer voice coil
  • Tweeter: 3/4" soft dome with ferrofluid cooling
  • Power handling: 80 watts RMS/160 watts max
  • Impedance: 4 ohms
  • Frequency response: 60-20,000 Hz
  • Sensitivity: 86 dB 1W/1m
  • Dimensions: 5.75" H x 14.94" W x 6.6" D *Depth includes removable grill*
Dayton Audio SUB-1200 12" 120 Watt Powered Subwoofer
The Dayton Audio SUB-1200 12" powered subwoofer system is the perfect addition to any home theater system. This powered sub features a bottom-firing, flared port, bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 12" woofer and up to 120 watts of house-shaking power.
  • Power output: 120 watts RMS
  • Frequency response: 25-140 Hz
  • Box design: Ported
  • Inputs: RCA line level & speaker level
  • Outputs: Speaker level
  • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave
  • Phase switch
  • Auto on/off
  • Power requirements: 120 VAC, 60 Hz
  • Dimensions (rubber feet included): 16.75" H x 16.19" W x 17.75" D.
Part Number300-648
UPC848864069234
Weight88.95
