Dayton Audio MK442T 5.1 Home Theater Speaker Bundle with 10" Powered Subwoofer Dayton Audio MK442T 4" 2-Way Transmission Line Tower Speaker Pair
The MK442T speakers offer amazing sound quality in an unbelievable form factor. The dual 4" woofers are easily able to play down to 40 Hz and still represent the vocal range accurately. Thanks in part to the efficient quarter wave transmission line enclosure, the MK442T digs deep and still achieves a small footprint. The 3/4" tweeter is capable of producing effortless high frequencies with a wide dispersion. These two drivers, paired with a painstakingly designed crossover system, create a soundstage that is sure to impress.
Specifications: • Design: 2-way dual 4" transmission line tower speaker • Woofer: Dual 4" high excursion driver with a treated paper cone • Tweeter: 3/4" soft dome • Finish: Black vinyl • Power handling: 80 watts RMS/160 watts max • Impedance: 4 ohms • Frequency response: 40 to 20,000 Hz • Sensitivity: 87 dB 1W/1m • Crossover: 3 kHz, 2nd order low pass, 3rd order high pass (acoustical slopes) • Terminals: 5-way gold plated binding posts • Dimensions: 38.1" H x 5.7" W x 9.6" D *Depth includes removable grill
Dayton Audio MK402X 4" 2-Way Bookshelf Speaker Pair
The MK402X speakers offer incredible sound quality in an almost unbelievable size. The drivers used in this design play a large role in this small speaker. The 4" woofer is easily able to play to 60 Hz and still play into the vocal range impressively. The 3/4" tweeter is capable of producing effortless high frequencies with a wide dispersion. These two drivers, paired with our simple yet effective crossover, create a soundstage that is sure to awe even the harshest of critics.
Specifications: • Design: 2-way vented bookshelf • Woofer: 4" high excursion driver with a treated paper cone • Tweeter: 3/4" soft dome • Finish: Black vinyl • Power handling: 40 watts RMS/80 watts max • Impedance: 4 ohms • Frequency response: 60 to 20,000 Hz • Sensitivity: 84 dB 1W/1m • Crossover: 3.3 kHz, 2nd order low pass, 3rd order high pass (acoustical slopes) • Terminals: 5-way gold plated binding posts • Port tuning: 50 Hz • Dimensions: 9.5" H x 5.75" W x 6.625" D.
Dayton Audio MK442 Dual 4" 2-Way Center Channel Speaker
The impressive sound quality offered by the Dayton Audio MK442 center channel speaker is awe-inspiring. The MK442 is designed to complement the Dayton Audio MK402X bookshelf speakers in a multichannel home theater system. It is able to reproduce frequencies as low as 60 Hz, and offers a natural sound with excellent sonic detail. The 3/4" soft dome tweeter paired with two 4" treated-paper cone woofers is a pairing made in audio heaven.
Specifications: • Woofer: 4" treated-paper cone with 4-layer voice coil • Tweeter: 3/4" soft dome with ferrofluid cooling • Finish: Black ebony pica vinyl on MDF • Power handling: 80 watts RMS/160 watts max • Impedance: 4 ohms • Frequency response: 60-20,000 Hz • Sensitivity: 86 dB 1W/1m • Crossover: Third order high-pass; second order low-pass • Terminals: 5-way binding posts • Port tuning: 57 Hz • Dimensions: 5.75" H x 14.94" W x 6.6" D *Depth includes removable grill
Dayton Audio SUB-1000 10" 100 Watt Powered Subwoofer
The Dayton Audio SUB-1000 10" powered subwoofer system is the perfect addition to any home theater system. This powered sub features a bottom-firing, flared port, bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 10" woofer and up to 100 watts of house-shaking power.
Specifications: • Power output: 100 watts RMS • Frequency response: 30-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions (plastic feet included): 14-3/4" H x 14-3/16" W x 15-3/4" D.
