  • Shadow Mounts LCD1330-TM Full-Motion TV Wall Mount Up To 30"
Shadow MountsPart # 182-376
Model: LCD1330-TM
Shadow Mounts place the focus on your flat panel television—not the mount. The LCD1130-TM full motion mount is compatible with flat panel TVs using VESA 75 and 100 mounting standards. Maximum supported weight is 50 lbs.
  • Unobtrusive black finish disappears behind flat panel TVs
  • ±30° swivel adjustment
  • ±15° tilt adjustment
  • Conforms to VESA 75 and 100 mounting standards
  • Mounting hardware and instructions included
See all items in TV Mounts & Brackets
Your Price: $21.49
Save $20.50 (49%)
We'll send you an email when Shadow Mounts LCD1330-TM Full-Motion TV Wall Mount Up To 30" is back in stock or available for preorder.
Order in the next 13 hr 23 min to ship today. Details
Shadow Mounts place the focus on your flat panel television—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Heavy-duty, solid-steel construction provides you with peace of mind knowing your HDTV investment is held securely in place for years to come. A full motion mount allows a viewer to tilt or swivel a flat panel TV into the optimum viewing position. A total of 60° swivel adjustment and 30° tilt adjustment offers almost unlimited placement options. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 3.1" (80 mm) W x 4.3" (109 mm) H • TV bracket: 4.3" (110 mm) W x 4.3" (110 mm) H • TV to wall distance: 3.9" (98 mm) • Swivel adjustment: ±30° • Tilt adjustment: ±15° • Supported VESA sizes: 75, 100 • Maximum weight capacity: 50 lbs. (23 kg).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelLCD1330-TM
Part Number182-376
UPC844632067853
Weight1.83
Mount StyleWall Mount
Mount TypeFull-Motion Articulating
TV Capacity32" or less
