  • Dayton Audio DTA-120BT Class D Mini Amplifier 60 WPC with Bluetooth and Power Supply
CLEARANCE Dayton Audio DTA-120BT Class D Mini Amplifier 60 WPC with Bluetooth and Power Supply
Dayton AudioPart # 300-3802
Model: DTA-120BT
Dayton Audio's DTA-120BT provides a rich feature set including Bluetooth 4.2 with aptX, RCA and 3.5 mm input, and headphone output. To further add to its appeal, the DTA-120BT produces 60 watts per channel which is more than enough for most speakers on the market.
  • Outstanding sonic clarity for enjoyable listening
  • Bluetooth 4.2 with aptX technology for wireless Hi-Fi listening
  • 1/4" headphone jack allows the unit to double as a high ?delity headphone ampli?er
  • Attractive extruded aluminum housing with thick black anodized faceplate
See all items in Legacy Items
We'll send you an email when Dayton Audio DTA-120BT Class D Mini Amplifier 60 WPC with Bluetooth and Power Supply is back in stock or available for preorder.
The All-in-one Package
Dayton Audio has updated the popular DTA-120 mini amplifier with the addition of Bluetooth audio but keeps the great sound and outstanding quality of the original DTA-120. The result is the Dayton Audio DTA-120BT Class D digital amplifier. It's everything you need in a mini amplifier, delivering the performance of large hi-fi gear paired with smart features, you'll wonder how you lived without... and thanks to the space-saving design, it fits and installs practically anywhere!
Small Powerhouse
The DTA-120BT amplifier delivers the power of a monster amplifier but in a tiny package. Thanks to its Class D technology, plus a robust Dual Parallel BTL configuration, the DTA-120BT tackles the toughest speaker loads with ease -- while delivering the sound quality and low distortion of a conventional Class AB amplifier. The dual-power-chip design delivers 60 watts RMS per channel of efficient power into a 4 ohm load (up to 120 watts total), and 40 watts RMS into 8 ohms, continuously, with no reduction in output. That means powerful bass and clear output that keeps on going, even with the most demanding speakers.
Compact and Discrete
With the DTA-120BT mini amplifier, you get the most power possible from the smallest footprint imaginable. At under 3-1/2" wide, 2" tall, and 7-1/2" deep, the DTA-120BT delivers more power per cubic inch than any other mini amplifier. All this is thanks to the revolutionary, cool-running Class D amplifier technology and the extruded aluminum heatsink case. The robust external switching power supply hides out of sight. But since it can supply high current with even higher peaks, the DTA-120BT can easily drive HUGE speakers.
Source-Friendly Option
In a world of wireless connectivity, the DTA-120BT offers a high-quality aptX Bluetooth connection as one of its multiple source options. Also offered are 3.5 mm and a pair of RCA auxiliary inputs to satisfy your analog input needs. The short signal paths inside the amplifier preserve all the quality of the input signal. No switches to flip, and just one knob. The DTA-120BT is the perfect complement to your smartphone, tablet, laptop, PC, television, or any other audio source.
More Than One Way to Listen
The DTA-120BT is the ultimate desktop amplifier. Not only can it power the most inefficient speakers to incredible levels without strain, making it perfect for powering desktop mini-monitor speakers, but it also offers a separate solid-state headphone amplifier stage capable of powering even high-impedance headphones to high listening levels while preserving clarity, detail, and a refined sonic character. However you like to listen at your desk, the DTA-120BT is the desktop companion.
• Output power: 60 watts RMS x 2 @ 4 ohms • Total harmonic distortion (THD): <0.1% @ 1W, <10% @ 60W • Frequency response: 20-20,000 Hz • Signal-to-noise ratio: 103 dB, A weighted • Input sensitivity: 680 mV • Inputs: Rear stereo RCA, front 3.5 mm stereo mini jack, and Bluetooth • Headphone output: 95 mW at 16 ohm • Outputs: Dual shielded, gold-plated mini binding posts (banana plugs accepted) • Bluetooth version: 4.2 • Power supply: Input: 100~240 VAC, 50/60 Hz, 1.6A; Output: 24 VDC, 5A • Power efficiency: >85% • Dimensions: Faceplate dimensions: 1.9" H x 3.37" W x 0.31" D • Body dimensions: 1.75" H x 3.12" W x 6.87" D • Overall dimensions: 2" H x 3.37" W x 7.5" D (including feet, faceplate, and volume knob).
Front Panel:
1. Power / Pairing LED
Blue LED indicates the unit is receiving power and is operational, this LED also indicates the pairing status for Bluetooth.
2. Power / Volume Control
This control knob turns the unit on or off, and adjusts the volume level of the amplifier.
3. Headphone Jack
The DTA-120BT is also a headphone ampli?er that will drive most headphones. The 1/4" stereo jack allows connection of most headphones. An adapter is provided so headphones with a 3.5 mm connector can be used.
Note: When headphones are plugged into the headphone jack the speaker output connections are disabled.
4. Pair Button
Use this button to pair (and unpair) devices for Bluetooth audio streaming. When the amp is turned on, it will automatically be in the pairing mode, as indicated by the power LED flashing slowly. At this time, you can pair the DTA-120BT by selecting it in the Bluetooth menu of your mobile device. To unpair and connect to a different mobile device, press the PAIR button on the DTA-120BT to re-enter pairing mode. When initially powered on, the DTA-120BT will attempt to connect to the first available device that has been previously paired. Bluetooth connection will take priority over any other input source.
5. 3.5 mm Audio Input
The unit features a convenient front mounted 3.5 mm stereo input for quick connection of iPods, MP3 players, and other portable audio devices. A 3.5 mm cable is included.
Note: When a device is plugged into the 3.5 mm input, the rear mounted RCA input jacks are disabled. This allows you to permanently connect a device to the rear RCA inputs, and switch to a portable device by simply plugging into the front mounted input.
Rear Panel:
6. Bluetooth Antenna
Turn this antenna to a vertical position prior to using the Bluetooth feature of the amplifier.
7. Power Connection
The DTA-120BT includes a universally compatible (100V-240V) switch mode power supply which is furnished with a USA style cord. To operate in other countries an appropriate power cord will need to be purchased.
Note: If an inappropriate power supply is used and the unit is damaged, the warranty will be voided.
8. Speaker Outputs
The speaker output connections utilize high current binding posts that are color coded for easy polarity identi?cation. High quality screw-on banana plugs that will accept 12 AWG-18 AWG wire are included.
9. RCA-Type Audio Input
RCA-type line level input for permanent connection of larger devices such as CD and DVD players. An RCA to 3.5 mm adapter is also provided for added connection ?exibility. Note: When a device is plugged into the front mounted 3.5 mm input, the RCA input jacks are disengaged
ModelDTA-120BT
Part Number300-3802
Weight2.8
