Rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system dramatically improves clarity, stereo imaging, and bass response. This is especially apparent with subwoofer systems. These attractive spikes are precision machined from solid brass and then plated with a durable finish. Barbed insert nuts and 32mm long (M6 x 0.7mm) threaded studs are included for mounting in cabinets with walls up to 1" thick. Set includes four cone spikes, four floor discs, four barbed insert nuts, and four threaded studs. Insert nut requires a 5/16" hole to be drilled in cabinet prior to installation. • Dimensions: 1" diameter, 1-3/16" high (including disc).
