  • Dayton Audio DSPB-KE Kernel DSP Expansion 2-In 3-Out
CLEARANCE Dayton Audio DSPB-KE Kernel DSP Expansion 2-In 3-Out
Dayton AudioPart # 325-131
Model: DSPB-KE
The Dayton Audio DSPB-KE is a quick connection board that adds your programmed DSPB-K board to your audio project using standard RCA and 3.5 mm input/output jacks.
  • Standard phono and 3.5 mm 3-conductor input/output jacks for quick connection
  • Two RCA input jacks and three output jacks for 2.1 channel audio projects
  • Includes standoffs and 10-pin wire harness for easy integration with the DSPB-K DSP board (sold separately)
We'll send you an email when Dayton Audio DSPB-KE Kernel DSP Expansion 2-In 3-Out is back in stock or available for preorder.
The DSPB-KE is the easy way to connect the DSPB-K DSP board to your audio project. The DSPB-KE has built-in RCA and 3.5 mm input/output jacks to quickly connect to audio amp boards or finished amplifiers. Two RCA input jacks and three output jacks make this board perfect 2.1 channel audio projects. It includes a 10-pin wiring harness that easily connects the DSPB-KE to the DSPB-K without having to figure out wiring diagrams. It also includes standoffs for stacking together the two small boards into tight spaces.
Specifications: • Dimensions: 1.97" W x 1.97" D x 0.67" H (50 x 50 x 17 mm) without jacks • Four mounting holes: 0.11" Dia. (2.8 mm), 1.77" (45 mm) apart to center.
ModelDSPB-KE
Part Number325-131
UPC848791006074
Weight0.16
Board TypePreamp
