  • Shadow Mounts DESKARM-D Articulating Desktop Dual Monitor Mount 13"-27"
CLEARANCE Shadow Mounts DESKARM-D Articulating Desktop Dual Monitor Mount 13"-27"
Shadow MountsPart # 182-396
Model: DESKARM-D
Increase your productivity while decreasing eye and neck strain with Shadow Mounts' dual monitor DESKARM.
  • Reclaim valuable desk space—requires only 3.5" x 4" of mounting area
  • Reduces neck and eye strain by placing monitor at optimum viewing height and angle
  • Heavy-duty design will not sag over time
  • Integrated cable management for a smart, clean appearance
  • Increases productivity and efficiency
  • Perfect for power users
See all items in Computer Monitor Mounts & Workstations
CLEARANCE $26.45
MSRP: $76.99
Save $50.54 (66%)
4 In Stock
We'll send you an email when Shadow Mounts DESKARM-D Articulating Desktop Dual Monitor Mount 13"-27" is back in stock or available for preorder.
Order in the next 12 hr 20 min to ship today. Details
Shadow Mounts' desktop monitor mounts are designed for computer monitors up to 27". Each mount is constructed of solid aluminum and steel for superior stability, even when fully extended—a Dayton Audio desktop mount will not flex or sag. Copper joints offer smooth, fluid tilt, pan, and swivel adjustments for maximum visibility no matter your seating position.
An ultra heavy-duty C-clamp, with integrated double lock system and three mounting depths permanently affixes the mount to your desktop (from 1/2" to 4" thick) in no time flat. Height adjustments are quick and easy, and monitors can be installed in either portrait or landscape positions effortlessly—rotating 360°—to fit your application perfectly.
Dual arm joints offer up to 360° of swivel viewing adjustment, while extending up to 16.5" freeing up crucial desk space. Integrated cable management provides a neat, clean appearance and all necessary installation hardware is included.
Specifications: • Mount arm length: Adjustable up to 16.5" L • Mount height: Adjustable up to 17.7" H • Attaches to desk tops from 1/2" to 4" thick • Tilt adjustment: ± 15° • Swivel adjustment: 360° • Rotate adjustment: 360° • Supports two monitors weighing up to 22 lbs. each • Compatible with 75 x 75 mm and 100 x 100 mm VESA patterns (for use with larger monitors, please see the Related Items section for VESA adapters).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelDESKARM-D
Part Number182-396
UPC844632094941
Weight13.55
Mount StyleDesk / Tabletop
Mount TypeFull-Motion Articulating
TV Capacity32" or less
