  • Dayton Audio DAC01 USB Audio DAC 24-bit/96 kHz RCA Output
Dayton AudioPart # 230-510
Model: DAC01
The Dayton Audio DAC01 USB interface provides superb digital-to-analog conversion in a perfectly portable package. With sampling rates up to 96 kHz/24-bit, the DAC will breathe new life into your computer based audio setup. The stereo RCA analog outputs can be connected to your active speakers or another power amplifier. Simple plug-and-play operation makes the Dayton Audio DAC01 USB audio DAC a perfect option to upgrade the sound of your PC's audio.
  • USB connectivity to PCs or other OTG enabled devices with plug-and-play operation
  • Audiophile sound quality with up to 96 kHz/24-bit sample rate
  • Stereo RCA analog outputs for connecting to active speakers, amplifier, or other audio device
  • Extremely small and portable for use on the go
  • USB bus powered
  • Package includes 4ft USB-B to USB-A cable
Your Price: $44.98
Save $14.01 (24%)
We'll send you an email when Dayton Audio DAC01 USB Audio DAC 24-bit/96 kHz RCA Output is back in stock or available for preorder.
Estimated back in stock 12/18/2026
Upgrade from your PCs on board soundcard with the Dayton Audio DAC01 USB audio DAC. The extremely portable digital-to-analog converter delivers audiophile sound quality with up to a 96 kHz/24-bit sampling rate. Stereo RCA analog outputs allow you to connect the unit to active speakers or to another device such as a power amplifier. Easily integrated into your current setup, the DAC01 is plug-and-play using USB protocol and is compatible with Mac and Windows OS as well as other devices using OTG audio technology. The USB bus powered DAC automatically powers on with sample rate indicators on the front of the unit. Realize the detail, clarity, and presence you have been missing from your PCs soundcard by upgrading to the impeccable sound quality of the Dayton Audio DAC01 USB audio interface.
Specifications: • Outputs: Stereo RCA • Chipset: PCM5102A • Sample rate: 44.1, 48, 88.2, or 96 kHz / 16 - 24 bit • Power input: 5 VDC USB bus powered • Voltage output: 1.64 VRMS/ch • THD: 0.002% • SNR: 110 dB • Dimensions: 1.26" H x 1.57" W x 3.54" D.
ModelDAC01
Part Number230-510
UPC848791005152
Weight0.55
