  • Dayton Audio DA60R 60W 70V Rack Mixer-Amplifier with (10) 8" Ceiling Speaker plus Tile Bridge
Parts ExpressPart # 247-5114
Parts Express has taken the powerful Dayton Audio DA60R 60 watt 70 volt amplifier and bundled it with ten 8" ceiling speakers and ten Fourjay PB8 ceiling bridges to provide installers with an affordable, all-in-one commercial audio package. Add speaker wire, input source, and patch connection cables for a complete contractor system.
  • All-in-one bundle perfect for schools, hospitals, retail stores, warehouses, and other commercial installs
  • Includes the Dayton Audio DA60R 60 watt 70/100 volt or 4-16 ohm commercial amplifier provides installers with high-output power while remaining flexible in application
  • Ten 8" full range, in-ceiling speakers with multi-tap 70 volt transformer
  • Robust 6-input amp with priority muting gives you an array of inputs for any source including mics, telephones, and background music
  • Full range, wide-dispersion speakers ideal for in-ceiling paging and background music
  • UL listed tile bridge supports the speakers in suspended acoustic tile ceilings
Your Price: $694.98
MSRP: $881.79
Save $186.81 (21%)
Eliminate Guess Work
Parts Express has taken the guesswork and confusion out of commercial paging and background music installations with this incredibly affordable contractor grade all-in-one bundle. By packaging the Dayton Audio DA60R commercial amplifier, ten 8" in-ceiling speakers, and ten UL listed tile bridges Parts Express gives you an extremely versatile, yet powerful audio system for commercial installations.
Perfectly Paired for Installations
Utilizing the DA60R amp and 8" in-ceiling speakers, this bundle provides you with both a powerful yet flexible system. With 60 watts of power, the DA60R is a workhorse of a commercial amp. Both 70/100 volt and 4-16 compatibility allow the amp to be used with both 70 volt speakers as well as residential 8 ohm speakers. The amp features three 1/4" XLR/TRS jacks, two RCA AUX connections, and terminal block telephone inputs to allow you to connect a variety of sources. Priority music muting allows you to temporarily duck background music while paging which makes speech intelligibility much clearer. The easy-to-use design amp cuts installation time which makes it simple to integrate into a current system or to design a new system around.
With ten 8" full range in-ceiling speakers, Parts Express gives you ideal loudspeakers for paging, background music, and fire signaling. The speakers produce a full range sound with wide dispersion for maximum coverage area. The built-in 70 volt transformer is perfect for use with the DA60R amp. The bundle includes a UL listed tile bridge for each speaker. The Fourjay PB8 is constructed from heavy duty galvanized steel which easily supports the speakers for assembly in suspended acoustic tile ceilings.
Flexible and Easy to Install
With this bundle you can count on a high-performing, flexible, and simple audio system that works great for commercial install applications. Parts Express provides you with the essential components for the backbone of background music and paging system perfect for schools, hospitals, retail stores, warehouses, and restaurants. Parts Express has taken out compatibility guesswork to ensure that you get the highest quality components for your next install at the absolute best prices.
Amplifier Specifications: • Maximum power output: 60W (1% THD) • Speaker output: 70V, 100V, 4 -16 ohm (mono, not to be used with mixed impedance loads) • Frequency response: 50 - 18,000 Hz • Mic input sensitivity/impedance: 5 mV, 600 ohms • Aux input sensitivity/impedance: 350mV, 10k ohms • Tel input sensitivity/impedance: 350mV, 10k ohms • Phantom power: +48V, switchable • Power input: 110 VAC, 60 Hz • Maximum power consumption: 100W • Dimensions: 19" W x 11.93" D x 3.466" H (484 x 303 x 88 mm) • Weight: 14.77 lbs. (6.7 kg).
Speaker Specifications: • Type: 8" full-range, in-ceiling • Magnet: 12 oz. ceramic • Voice coil: 1" aluminum • Frequency response: 45-15,000 Hz • Transformer taps: 0.63, 1.25, 2.5, 5, 10W • Mounting holes: 11.25" CTC • Cutout dimensions: 8.27" • Dimensions: 12.9" OD x 2.95" D.
Tile Bridge Specifications: • Inside cutout diameter: 7.5" • 14" W x 23-3/4" L • Screw holes: 9-1/8" and 11-1/4" diameter circles.
Part Number247-5114
UPC848791006289
Weight76.28
