  • Dayton Audio CSK658 6-1/2" Plenum Speaker Kit Pair with Wire
CLEARANCE Dayton Audio CSK658 6-1/2" Plenum Speaker Kit Pair with Wire
Dayton AudioPart # 300-399
Model: CSK658
The speaker features a 6-1/2" carbon fiber cone with a butyl rubber surround, a coaxial mounted 1" Mylar dome tweeter. Install ceiling speakers in schools, offices and institutions in compliance with fire codes and the NEC.
  • Meets UL 2043 specifications
  • 6-1/2" carbon fiber woofer and 1" mylar dome tweeter
  • Includes 100 ft. of 18 AWG plenum rated speaker cable
  • Easy installation
  • 30 watts RMS/45 watts max
CLEARANCE $119.39
Save $99.60 (45%)
6 In Stock
Order in the next 2 hr 21 min to ship today. Details
Install ceiling speakers in schools, offices and institutions in compliance with fire codes and the NEC. The key to this system is the UL listed protective metal enclosure that contains the speaker within the plenum space. The metal enclosure locks into place in the metal ceiling bridge that supports the metal enclosure from the ceiling T-bars for added installation safety. When used with the supplied plenum rated speaker cable, this system meets UL 2043 specifications. The speaker features a 6-1/2" carbon fiber cone with a butyl rubber surround, a coaxial mounted 1" mylar dome tweeter. To ease installation the speaker has removable steel mesh grills, built-in mounting brackets, hardware, and installation instructions.
Specifications: • Power handling: 30 watts RMS/45 watts max • Impedance: 8 ohms • Frequency response: 60-20,000 Hz • SPL: 89 dB 1W/1m • Dimensions: 8-1/2" dia. x 2-3/4" D • Cutout size: 7-3/8" dia. • Sold in pairs.
ModelCSK658
Part Number300-399
UPC844632082443
Weight20.55
Input Rating8 ohm
Mounting StyleIn-ceiling
Woofer Diameter6.5"
Special FeaturesEnclosed Back-UL2043
