  • Dayton Audio CE Series CE67PR-4 2" Neo Extended Range Speaker Driver 15W 4 Ohm
CLEARANCE Dayton Audio CE Series CE67PR-4 2" Neo Extended Range Speaker Driver 15W 4 Ohm
Dayton AudioPart # 285-173
Model: CE67PR-4
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High Economic Value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
CLEARANCE $3.33
MSRP: $12.99
Save $9.66 (74%)
266 In Stock
We'll send you an email when Dayton Audio CE Series CE67PR-4 2" Neo Extended Range Speaker Driver 15W 4 Ohm is back in stock or available for preorder.
This speaker is primed for any commercial or DIY audio project. Despite its size, Dayton Audio's 2-inch neodymium driver packs an extended range and bass response tailor-made for high-impact applications. With a 4-ohm impedance and power handling of 15 watts, this speaker can drive serious sound into tight spaces without distortion. It's ideal for adding audio to digital signage, kiosks, point-of-sale systems and more. When space is at a premium but fidelity and oomph are must-haves, Dayton's micro speaker delivers full-range audio in an economic package. For small-scale installations where every decibel and dollar counts, this speaker is a sound solution.
ModelCE67PR-4
Part Number285-173
UPC848791009358
Weight0.25
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response218 - 20,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter20"
Resonant Frequency (Fs)218Hz
DC Resistance (Re)4.54Ω
Voice Coil Inductance (Le)0.14mH
Mechanical Q (Qms)5.52
Electromagnetic Q (Qes)1.11
Total Q (Qts)0.92
Mechanical Compliance of Suspension (Cms)0.29mm/N
BL Product (BL)3.22T·m
Diaphragm Mass Inc. Airload (Mms)1.8g
Maximum Linear Excursion (Xmax)2.2mm
Surface Area of Cone (Sd)16.62cm²
