  • Dayton Audio CE Series CE53N-4 2" Dual Neo Full-Range Speaker Driver 10W 4 Ohm
Dayton AudioPart # 285-171
Model: CE53N-4
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High Economic Value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
Your Price: $9.98
Save $3.01 (23%)
We'll send you an email when Dayton Audio CE Series CE53N-4 2" Dual Neo Full-Range Speaker Driver 10W 4 Ohm is back in stock or available for preorder.
Don't let the size of Dayton Audio's CE53N-4 2-inch full-range speaker fool you-it's built for business. Under the hood, a neodymium magnet and anodized aluminum diaphragm deliver clear, balanced sound ideal for commercial applications where space is at a premium. With a 4-ohm impedance, this speaker plays nicely with a range of amplifiers, making it easy to integrate into any small-scale sound system or DIY project. And because it's designed specifically for the rigors of commercial use, you can install this speaker just about anywhere-from retail stores to restaurants to trade shows-knowing it will keep cranking out the tunes day after day. Big sound, small package, affordable price-the CE53N-4 is an audio solution for shoestring budgets and small spaces. Your customers and clients will thank you for the upgrade.
ModelCE53N-4
Part Number285-171
UPC848791009341
Weight0.2
Nominal Diameter2"
Bolt Circle Diameter2.28
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Impedance4Ω
Frequency Response200 -20,000Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter16"
Resonant Frequency (Fs)197Hz
DC Resistance (Re)3.47Ω
Voice Coil Inductance (Le)0.07mH
Mechanical Q (Qms)5.4
Electromagnetic Q (Qes)1.3
Total Q (Qts)1
Compliance Equivalent Volume (Vas)0.0053ft³
Mechanical Compliance of Suspension (Cms)0.75mm/N
BL Product (BL)1.71T·m
Diaphragm Mass Inc. Airload (Mms)0.87g
Surface Area of Cone (Sd)8.55cm²
Cone MaterialAluminum
Magnet MaterialNeodymium
Overall Outside Diameter2.65"
Baffle Cutout Diameter1.85"
Depth1.3"
