  • Dayton Audio CE Series CE4895-8 2" x 3.75" Racetrack Full-Range Speaker Driver 22W 8 Ohm
Dayton AudioPart # 285-187
Model: CE4895-8
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High Economic Value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
Your Price: $8.98
Save $3.01 (25%)
316 In Stock
We'll send you an email when Dayton Audio CE Series CE4895-8 2" x 3.75" Racetrack Full-Range Speaker Driver 22W 8 Ohm is back in stock or available for preorder.
This full-range wonder may be small in size, but it's big on sound. Dayton Audio's CE4895-8 racetrack speaker punches well above its dimensions, delivering 22 watts of rich, full-bodied audio in a package measuring just 2 by 3.5 inches. Despite its commercial-grade durability, this speaker is a DIY enthusiast's dream come true for small projects. Its high aspect ratio means broad dispersion and a wide sweet spot, while its 8-ohm impedance plays nicely with a variety of amps. For micro installations where space is at a premium but sound quality cannot be compromised, this miniature maestro hits the high notes. Affordable, no-nonsense, and ready to rock right out of the box, the CE4895-8 proves that the best things in audio come in small packages.
ModelCE4895-8
Part Number285-187
UPC848791009426
Weight0.85
Nominal Diameter2 x 3"
Power Handling (RMS)22 Watts
Power Handling (MAX)44 Watts
Frequency Response100 - 15,000Hz
Sensitivity85dB 2.83V/1m
Voice Coil Diameter0.63"
Resonant Frequency (Fs)123Hz
DC Resistance (Re)7.3Ω
Voice Coil Inductance (Le)0.53mH
Mechanical Q (Qms)5.75
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.53
Compliance Equivalent Volume (Vas)0.019ft³
Mechanical Compliance of Suspension (Cms)0.61mm/N
BL Product (BL)5.17T·m
Diaphragm Mass Inc. Airload (Mms)2.72g
Maximum Linear Excursion (Xmax)1.8mm
Surface Area of Cone (Sd)25.4cm²
Cone MaterialPaper
Depth2"
