  • Dayton Audio CE Series CE4249N-4 1.5" Dual Neo Full-Range Speaker Driver 5W 4 Ohm
CLEARANCE Dayton Audio CE Series CE4249N-4 1.5" Dual Neo Full-Range Speaker Driver 5W 4 Ohm
Dayton AudioPart # 285-159
Model: CE4249N-4
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High Economic Value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
CLEARANCE $2.33
MSRP: $7.99
Save $5.66 (71%)
885 In Stock
We'll send you an email when Dayton Audio CE Series CE4249N-4 1.5" Dual Neo Full-Range Speaker Driver 5W 4 Ohm is back in stock or available for preorder.
Order in the next 3 hr 5 min to ship today. Details
Don't let the size of Dayton Audio's CE4249N-4 1.5" speaker fool you-it's a commercial-grade workhorse that punches well above its weight. Built around a neodymium magnet, it produces crisp highs, balanced mids and surprisingly robust bass for its size. Rated at 5 watts and 4 ohms, it's ideal for small commercial installations, DIY projects, and cost-effective manufacturing applications where space is at a premium but quality can't be compromised. Despite its affordable price, this speaker is all business, with durable construction that keeps pumping out the jams long after cheaper alternatives have called it quits.
ModelCE4249N-4
Part Number285-159
UPC848791009280
Weight0.1
Power Handling (RMS)5 Watts
Power Handling (MAX)10 Watts
Frequency Response200 - 20,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.62"
Resonant Frequency (Fs)184Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)0.13mH
Mechanical Q (Qms)6.67
Electromagnetic Q (Qes)0.53
Total Q (Qts)0.49
Compliance Equivalent Volume (Vas)0.001ft³
Mechanical Compliance of Suspension (Cms)0.49mm/N
BL Product (BL)2.94T·m
Diaphragm Mass Inc. Airload (Mms)1.2g
Maximum Linear Excursion (Xmax)1.6mm
Surface Area of Cone (Sd)6.6cm²
