  • Dayton Audio CE Series CE41N-4 1.5" Dual Neo Full-Range Speaker Driver 5W 4 Ohm
Dayton AudioPart # 285-157
Model: CE41N-4
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High Economic Value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
Your Price: $6.98
Save $3.01 (30%)
286 In Stock
We'll send you an email when Dayton Audio CE Series CE41N-4 1.5" Dual Neo Full-Range Speaker Driver 5W 4 Ohm is back in stock or available for preorder.
Don't let the size of these 1.5-inch full-range drivers fool you-their neodymium magnets and 4-ohm impedance give them the power to pump out crisp highs, balanced mids and surprisingly solid bass for their size. Perfect for commercial installations, small projects, DIY speaker builds or any space-constrained application, these micro speakers are an economical solution for adding high-quality audio where larger drivers won't fit. These overachieving speakers deliver audiophile-grade sound at a budget-friendly cost, making them a no-brainer for manufacturers, builders and hobbyists alike.
ModelCE41N-4
Part Number285-157
UPC848791009273
Weight0.15
Power Handling (RMS)5 Watts
Power Handling (MAX)10 Watts
Frequency Response150 - 20,000Hz
Sensitivity83dB 2.83V/1m
Voice Coil Diameter0.62"
Resonant Frequency (Fs)170Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.06mH
Mechanical Q (Qms)5.6
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.53
Compliance Equivalent Volume (Vas)0.027ft³
Mechanical Compliance of Suspension (Cms)1.11mm/N
BL Product (BL)2.3T·m
Diaphragm Mass Inc. Airload (Mms)0.8g
Maximum Linear Excursion (Xmax)0.7mm
Surface Area of Cone (Sd)7.1cm²
