  • Dayton Audio CE Series CE36-8 1.5" Full-Range Speaker Driver 3W 8 Ohm
CLEARANCE Dayton Audio CE Series CE36-8 1.5" Full-Range Speaker Driver 3W 8 Ohm
Dayton AudioPart # 285-153
Model: CE36-8
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High Economic Value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
We'll send you an email when Dayton Audio CE Series CE36-8 1.5" Full-Range Speaker Driver 3W 8 Ohm is back in stock or available for preorder.
The Dayton Audio CE36-8 micro speakers pack full-bodied sound into a compact 1.5-inch frame. These workhorses are built for business, ready to provide robust audio in commercial settings where space is at a premium. The CE36-8's are also ideal for small DIY projects, adding high-quality sound to everything from custom cabinetry to digital signage. Their wide dispersion, full-range sound and affordable price point make these mighty mites a no-brainer for any small-scale installation. While other micro speakers skimp on substance, the CE36-8's are all about fidelity. For commercial, economic solutions or DIY designs where every decibel and dollar count, Dayton Audio's CE36-8 1.5-inch full-range speakers is the perfect choice.
ModelCE36-8
Part Number285-153
UPC848791009259
Weight0.1
Nominal Diameter1"
Power Handling (RMS)3 Watts
Power Handling (MAX)6 Watts
Frequency Response200 - 19,000Hz
Sensitivity81dB 2.83V/1m
Voice Coil Diameter0.51"
Resonant Frequency (Fs)200Hz
DC Resistance (Re)7.3Ω
Voice Coil Inductance (Le)0.15mH
Mechanical Q (Qms)4.18
Electromagnetic Q (Qes)0.88
Total Q (Qts)0.73
Compliance Equivalent Volume (Vas)0.001ft³
Mechanical Compliance of Suspension (Cms)0.79mm/N
BL Product (BL)2.41T·m
Diaphragm Mass Inc. Airload (Mms)0.73g
Maximum Linear Excursion (Xmax)0.9mm
Surface Area of Cone (Sd)6.2cm²
