  • Dayton Audio CE Series CE28N-4 1" Neo Extended Range Speaker Driver 2W 4 Ohm
Dayton AudioPart # 285-149
Model: CE28N-4
Engineered specifically with manufacturers and DIY enthusiasts in mind, these economically priced speakers deliver impressive performance without breaking the bank. Though compact in size, they pack a powerful punch! Whether you're a manufacturer seeking reliable components or a DIY project lover looking for the perfect sound solution, our CE Series drivers offer an optimal blend of size, price, and performance that's hard to resist.
  • High economic value
  • Delivers crisp, clear audio, ensuring an immersive listening experience
  • High-quality audio solutions without breaking the bank, ideal for budget-conscious projects
  • Suitable for commercial use, DIY projects, art exhibits, and more
Your Price: $4.48
Save $1.51 (25%)
98 In Stock
We'll send you an email when Dayton Audio CE Series CE28N-4 1" Neo Extended Range Speaker Driver 2W 4 Ohm is back in stock or available for preorder.
Order in the next 1 hr 48 min to ship today. Details
The Dayton Audio CE28N-4 1" Neo Extended Range 2W speaker punches above its weight with a neodymium magnet motor that delivers crisp highs and balanced low-end ideal for commercial installations on a budget. Though small, this micro speaker is an economic powerhouse perfect for small retail spaces, art exhibits, and DIY projects where an inconspicuous yet impactful audio solution is needed. Despite its dimensions, the CE28N-4's extended range reproduction and broad dispersion provide full, rich sound that permeates the space. For high-quality audio without the high cost or hassle, Dayton's manufacturing expertise hits the sweet spot.
ModelCE28N-4
Part Number285-149
UPC848791009235
Nominal Diameter1"
Power Handling (RMS)2 Watts
Power Handling (MAX)4 Watts
Impedance4Ω
Frequency Response400 - 20,000Hz
Sensitivity81dB 2.83V/1m
Voice Coil Diameter0.63"
Resonant Frequency (Fs)456Hz
DC Resistance (Re)3.79Ω
Voice Coil Inductance (Le)0.06mH
Mechanical Q (Qms)2.73
Electromagnetic Q (Qes)1.24
Total Q (Qts)0.85
Compliance Equivalent Volume (Vas)0.0002ft³
Mechanical Compliance of Suspension (Cms)0.42mm/N
BL Product (BL)1.56T·m
Diaphragm Mass Inc. Airload (Mms)0.29g
Maximum Linear Excursion (Xmax)0.35mm
Surface Area of Cone (Sd)3.1cm²
