  • Dayton Audio CE Series CE140-30S-8 1" x 5" Extended Range Speaker Driver 8 Ohm
Dayton AudioPart # 285-145
Model: CE140-30S-8
The CE140-30S-8 by Dayton Audio is a 1" x 5" tall-aspect-ratio extended range driver with a flat sandwich-construction diaphragm and a compact neodymium motor, for applications requiring a very narrow format yet wide-bandwidth driver.
  • Tall aspect ratio flat diaphragm for wide dispersion
  • Compact neodymium magnet structure
  • Low profile stamped steel frame
  • Copper voice coil on vented Kapton former
  • Suitable as a mid-woofer or extended range driver
Your Price: $14.79
MSRP: $19.99
Save $5.20 (26%)
Quantity:Qty: 1-3 $14.79/ea
Quantity:Qty: 4+ $13.44/ea
778 In Stock
We'll send you an email when Dayton Audio CE Series CE140-30S-8 1" x 5" Extended Range Speaker Driver 8 Ohm is back in stock or available for preorder.
Order in the next 15 hr 31 min to ship today. Details
The Commercial Engineering (CE) Series drivers from Dayton Audio provides engineers, designers, and integrators with a line of economical small drivers that fit the diverse range of applications found in consumer electronics and audio-enabled electronic projects.
The Dayton Audio CE140-30S-8 is a 1" x 5" driver for applications requiring a narrow format, yet wide bandwidth. The flat diaphragm uses a sandwich construction composed of woven glass fiber skins over a paper honeycomb core, for an excellent combination of stiffness and damping – often difficult to achieve in a flat diaphragm. The compact neodymium motor provides long-throw performance in a small form factor, enabling the driver frame to be only 1.4" wide.
The rugged, low-profile stamped steel frame features screw mounting holes for simplified installation. Use the CE140-30S-8 as a wide-bandwidth driver, or as a narrow-format midwoofer driver for high-fidelity music.
ModelCE140-30S-8
Part Number285-145
UPC848791001161
Weight0.19
Nominal Diameter1 x 5"
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Frequency Response100 to 8,500Hz
Sensitivity76dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)105Hz
DC Resistance (Re)7.75Ω
Voice Coil Inductance (Le)0.78mH
Mechanical Q (Qms)4.64
Electromagnetic Q (Qes)1.35
Total Q (Qts)1.04
Mechanical Compliance of Suspension (Cms)0.47mm/N
BL Product (BL)4.34T·m
Surface Area of Cone (Sd)25.1cm²
Cone MaterialFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter5.4" x 1.5"
Baffle Cutout Diameter4.88" x 1.19"
Depth1.4"
