  • Dayton Audio AERO Wi-Fi Bluetooth Speaker with IR Remote Control Black
CLEARANCE Dayton Audio AERO Wi-Fi Bluetooth Speaker with IR Remote Control Black
Dayton Audio
Part #300-6504
Dayton Audio
Part #300-6504
Model: AERO
The app controlled AERO wireless powered speaker features dual 3" premium drivers, rear facing passive bass radiator, 3.5 mm Aux input, 4.0 Bluetooth and 2.4 GHz Wi-Fi network connections, IR remote control and a touch capacitive speaker control panel. The rich and colorful sound that is produced from this small but elegant speaker is due to the wooden acoustic cabinet and premium driver design. Packed with quality features and craftsmanship the AERO is a true value.
  • Two 3" woofers and a rear-facing passive radiator deliver full range audio
  • Wooden acoustic cabinet creates rich, colorful sound
  • Connect via Wi-Fi, Bluetooth, or 3.5 mm AUX-in
  • Stream and control audio straight from the free Hi-Fly app
  • Group multiple speakers to create a wireless, app controlled multi-room sound system
  • Capacitive touch buttons and wireless remote controls volume and more
Your Current Sound System Redefined
This powered Wi-Fi speaker is easy to set-up; and easy to control using the Hi-Fly app. Add multiple speakers for a quick, affordable whole-house audio system.
MULTI-ROOM
Play synchronized audio in multiple rooms for seamless listening.
MULTI-CHANNEL
Play any song to any single device or group devices together.
MULTI-USER
Different users can control the audio source for different devices.
Music On Your Terms
Let your audio listening experience soar with the new Hi-Fly™ multi-room Wi-Fi audio technology from Dayton Audio. With the Hi-Fly App, you can stream your favorite online music services or listen to music directly from your device. The Dayton Audio AERO Wi-Fi powered speaker works in harmony with the Hi-Fly App to provide the ultimate in affordable multi-room, multi-channel, and multi-user audio.
CONNECTION FLEXIBILITY
Cut the cords and choose from 2.4GHz Wi-Fi or Bluetooth 4.0 connection.
CONVENIENCE FEATURES
Touch capacitive speaker controls and IR remote provide easy access to functions.
CRAFTSMANSHIP
The wooden acoustic speaker design delivers premium performance with style.
Craftsmanship to be Heard
The Dayton Audio AERO dual Wi-Fi and Bluetooth speaker is just part of the growing “Hi-Fly” multi-room audio family. Stylishly designed to blend with virtually any décor, the AERO features an acoustical wooden design, premium dual 3" drivers and a rear passive bass radiator which combine to deliver rich, colorful sound. Connect to the AERO using 4.0 Bluetooth or 2.4 GHz Wi-Fi, the IR remote control adds optimal convenience.
The Hi-Fly app is free and can be downloaded from any Android™ or Apple® device. With the Hi-Fly App, you can stream online music, listen to songs directly from your device, even listen to music from your home network. You can group or ungroup speakers and select playback from different sources using your tablet or mobile device. The Hi-Fly Multi-room technology makes it possible to play any song in any room or play the same song in all rooms. Plus, your music continues to play even if your phone is turned off or you need to take a call. Set-up is effortless, making it easy to add multiple speakers for instant whole-house audio.
Super Simple Setup
Setting up the AERO speaker is simple, start by downloading the free Dayton Audio Hi-Fly™ App from either the Play Store or App Store. Once the App is installed, open it on your mobile device or tablet and follow the step by step directions. If using a wired connection, the directions in the app are not required; just open the app and your device is ready for use.
Control the Airwaves at Home
The Dayton Audio Hi-Fly™ App turns your mobile device or tablet into a remote control for all Dayton Audio Hi-Fly™ enabled devices. Play music from your favorite streaming providers like Spotify, or from your home network or mobile device. With Hi-Fly you can send music to individual AERO adapters, or group your Hi-Fly enabled systems together for true multi-room audio. Plus, your music continues to play even if your phone is turned off or you need to take a call.
Specifications: • Connect: Wi-Fi, Bluetooth, 3.5 mm AUX line in • Wi-Fi standard: 802.11b/g/n 2T2R • Wi-Fi frequency range: 2.412 GHz-2.484 GHz • Security format: WEP/WPA-PSK/WPA2-PSK/WAPI • Security type: WEP64/WEP128/TKIP/AES • Streaming protocol: DLNA, UPNP • Sampling rate: 16 kHz-192 kHz/24 bits • Support devices: iOS and Android • Bluetooth standard: Bluetooth 4.0 Class II • Bluetooth frequency range: 2.4~2.48 GHz ISM Band • Bluetooth profiles: A2DP, AVRCP • RF power: 8 dBm • Operation range: 10m • Power output: 2 x 10 watts RMS, 1 bass radiator • SNR: >80 dB • THD: <1% • Input sensitivity: 600mV • Frequency response: 60 Hz-18 kHz ±3 dB • Sound pressure: 82 dB/m • Speaker driver: 3" x 2 • Speaker impedance: 4 ohms • Music service support TIDAL, Spotify, iHeartRadio, TuneIn, DLNA, Airplay • Power adapter: AC 100~240V, 50~60Hz, 12V/2A output • Dimensions: 8-3/4" W x 5-3/4" H x 4-1/4" D.
Powered by Linkplay Wi-Fi audio technology.Click here to learn more about custom integration of Linkplay technology in your products.
ModelAERO
Part Number300-6504
UPC848791002779
Weight5.8
