CLEARANCE 80 Watt Subwoofer Plate Amplifier with 3 dB Bass Boost at 45 Hz
Factory BuyoutsPart # 309-627
Build a budget subwoofer and rock the house with this 80 Watt subwoofer plate amplifier. Utilizing a 3 dB bass boost centered at 45 Hz, this amplifier is an ideal candidate for small sealed subwoofers.
- 3 dB Bass Boost @ 45 Hz
- Mono Class AB output stage for solid, well defined output
- Low-level and high-level inputs connect to any system
- Manual and Auto on/off modes for compatibility with any automated system
- Variable gain, crossover point and switchable phase controls optimize room integration
See all items in Subwoofer Plate Amplifiers Get Notified When Available
We'll send you an email when 80 Watt Subwoofer Plate Amplifier with 3 dB Bass Boost at 45 Hz is back in stock or available for preorder.
