  • 80 Watt Subwoofer Plate Amplifier with 3 dB Bass Boost @ 40 Hz
CLEARANCE 80 Watt Subwoofer Plate Amplifier with 3 dB Bass Boost @ 40 Hz
Factory BuyoutsPart # 309-639
Read 2 Reviews or
Build a budget subwoofer and rock the house with this 80-Watt subwoofer plate amplifier. Utilizing a 3 dB bass boost centered at 40 Hz, this amplifier is an ideal candidate for small sealed or ported subwoofers.
  • 3 dB Bass Boost @ 40 Hz
  • Mono Class AB output stage for solid, well defined output
  • Low-level and high-level inputs connect to any system
  • Manual and Auto on/off modes for compatibility with any automated system
  • Variable gain, crossover point and switchable phase controls optimize room integration
We'll send you an email when 80 Watt Subwoofer Plate Amplifier with 3 dB Bass Boost @ 40 Hz is back in stock or available for preorder.
If you are in need of a budget subwoofer amplifier, look no further. Boasting 80 watts of output into 4 ohms with 3 dB of bass boost at 40 Hz, this amplifier is the perfect candidate for DIY subwoofer or as a replacement or upgrade amplifier to an existing subwoofer.
This amplifier includes several features not always found in this price range - including speaker level and line level inputs, variable gain, crossover adjustment from 40-140 Hz, a selectable 0-180º phase switch and switchable auto-on power input.
Specifications: • Measured power output: 50 watts RMS into 8 ohms @ 0.1% THD, 80 watts RMS into 4 ohms @ < 1.0% THD • Signal to noise ratio: 96 dB A-weighted • Input impedance: 10.4K ohms • Bass boost: 3 dB @ 40 Hz • Low pass adjustment: 40 Hz to 140 Hz • Phase adjustment: 0º (normal) 180º (reverse) • Power requirements: 120VAC, 60 Hz • Dimensions: 7.125" W x 9" H x 2.5" D • Cutout dimensions: 5.75" W x 8" H.
BrandFactory Buyouts
Part Number309-639
UPC848791008184
Weight4.45
