  • DataComm 45-0006-WH 1-3/4" Cable Pass-Through Hole Saw Plate - White
DataComm ElectronicsPart # 261-503
Model: 45-0006-WH
Conceal low voltage cables with the low profile hole saw plate.
  • Low profile for fitting behind the thinnest mounts and TVs
  • Conceal low voltage cables to clean up messy wires
  • Great for HDMI, security, and speaker cable pass-through
  • Metal mounting wings for a secure install
  • No low voltage mounting bracket required
Your Price: $5.99
Save $4.00 (40%)
We'll send you an email when DataComm 45-0006-WH 1-3/4" Cable Pass-Through Hole Saw Plate - White is back in stock or available for preorder.
Order in the next 1 hr 19 min to ship today. Details
Easy installation is a huge plus with this hole saw plate. For a secure install, no low voltage mounting brackets are required, as all you need are the metal mounting wings that are attached to the plate. Pass low voltage cabling to conceal messy cables. The low profile deign is perfect for fitting behind the thinnest of TVs and mounts.
Specifications: • Color: White • Faceplate dimensions: 2"H x 2"W.
BrandDataComm Electronics
Model45-0006-WH
Part Number261-503
UPC660559008249
FinishWhite
SizeIrregular
