  • DS18 SLC-N69X 6"x9" 5-Way 260W Coaxial Speaker Pair 4 Ohm
CLEARANCE DS18 SLC-N69X 6"x9" 5-Way 260W Coaxial Speaker Pair 4 Ohm
DS18Part # 294-8008
Model: SLC-N69X
1 Question, 1 Answer or
The DS18 SLC-N69X 6"x9" 5-way speaker pair is a great drop-in upgrade for your vehicle's lackluster factory speakers. With a poly cone woofer, Mylar midrange and dual tweeters this full-range coaxial speaker will deliver a balanced sound with amazing detail.
  • 6" x 9" injection molded poly cone with rubber surround for long life and smooth response
  • 1-3/8" Mylar dome midrange, and 3 piezo tweeters deliver accurate and detailed high frequencies
  • Standard size for an easy drop-in installation in many factory mounting locations
  • Included grills offer protection with a modern look
  • High performance audio for an exceptional value
We'll send you an email when DS18 SLC-N69X 6"x9" 5-Way 260W Coaxial Speaker Pair 4 Ohm is back in stock or available for preorder.
<p>The SLC-N69X 6"x9" 5-Way speaker pair from DS18 makes it easy to give your car stereo system premium sound on a budget. It's injection molded poly cone woofer with rubber surround is driven by a 1" voice coil to handle up to 65 watts RMS (260 watts max) for high output capability with reliable performance. Coaxially mounted midrange and high frequency drivers produce excellent detail and clarity with wide dispersion. Designed with standard size and mounting points, the SLC-N69X is the perfect way to upgrade your car stereo without breaking the bank. </p>
<p><strong>Note:</strong> Grills, speaker wire, and mounting hardware included</p>
<p><h2>Specifications:</h2>
<br>• <strong>Type: </strong>6"x9" 5-way full range
<br>• <strong>Woofer: </strong>6" x 9" Polypropylene
<br>• <strong>Mid-range: </strong>1-3/8" Mylar dome
<br>• <strong>Tweeter: </strong>1", 3/4", and 1/2" piezo
<br>• <strong>Power handling: </strong>65 watts RMS (260 watts max)
<br>• <strong>Frequency response: </strong>45-20,000 Hz
<br>• <strong>Sensitivity: </strong>85.4 dB 1W/1m
<br>• <strong>Impedance: </strong>4 ohms
<br>• <strong>Voice coil: </strong>1" diameter
<br>• <strong>Basket structure: </strong>Stamped steel
<br>• <strong>Magnet weight: </strong>20 oz
<br>• <strong>Mounting depth: </strong>3"
</p>
BrandDS18
ModelSLC-N69X
Part Number294-8008
UPC663593061539
Unit of MeasurePairs
Weight6.75
Speaker Size6"
Power Handling (RMS)65 Watts
