  • DS18 PRO-ZT8 8" Professional Water Resistant Coaxial Speaker 4 Ohm
CLEARANCE DS18 PRO-ZT8 8" Professional Water Resistant Coaxial Speaker 4 Ohm
DS18Part # 294-8046
Model: PRO-ZT8
The unique PRO-ZT8 from DS18 combines a high efficiency 8" midrange with a coaxially mounted bullet tweeter to create a driver that can produce remarkably powerful output from 65 to 22,000 Hz while taking up minimal space. With a water-resistant cone, this driver is a great choice for use on motorcycles and ATVs. The included black metal mesh grille gives the PRO-ZT8 a great look while protecting it from damage.
  • 98 dB efficiency for high output capability even with moderately powered systems
  • Handles up to 275 watts RMS to deliver extreme overall SPL
  • Water-resistant treatment makes this driver perfect for use in damp locations
  • Coaxially mounted bullet tweeter ensures accurate and detailed response up to 22,000 Hz
  • Rugged black metal mesh grille looks great and protects driver from foreign objects
CLEARANCE $113.95
Only 2 In Stock
We'll send you an email when DS18 PRO-ZT8 8" Professional Water Resistant Coaxial Speaker 4 Ohm is back in stock or available for preorder.
Capable of high SPL midrange and high frequency response, DS18's PRO-ZT8 8" professional water-resistant coaxial speaker is the perfect choice to provide music at levels that can cut through the wind and engine noise from motorcycles or ATVs. The foundation of the PRO-ZT8 is a high efficiency 8" treated paper cone midrange that has a powerful motor with a non-resonant diaphragm. With a 1-1/2" voice coil on a Kapton former this driver can handle up to 275 watts RMS (with recommended crossover of 80 Hz) for incredible output capability. The high frequencies are handled by a coaxially mounted 1" aluminum bullet tweeter that can put the sound right where you want it thanks to its controlled dispersion. For an extra level of protection, a rugged metal mesh grille is included to keep foreign objects away from any fragile parts. All of this makes the unique PRO-ZT8 an excellent choice when you need high SPL but have limited installation space.
Overall Specifications:
• Nominal diameter: 8"
• Impedance: 4 ohms
• Power handling: 275 watts RMS/550 watts max
• Sensitivity: 98 dB 1W/1m
• Frequency response: 65-22,000 Hz
• Recommended crossover: 80 Hz high pass
Specifications (midrange):
• Voice coil diameter: 1-1/2"
• Voice coil former: Kapton
• Voice coil wire: CCAW
• Basket material: Steel
Specifications (tweeter):
• Voice coil diameter: 1"
• Diaphragm material: Aluminum alloy
• Magnet: 0.44 oz Neodymium
Dimensions:
• Outside diameter: 8.42"
• Cutout diameter: 7.13"
• Mounting depth: 3.58"
• Overall depth: 4.44"
BrandDS18
ModelPRO-ZT8
Part Number294-8046
UPC810005180764
Weight5.65
Sealed Volume0.63ft³
Sealed F3138.1Hz
Vented Volume0.88ft³
Vented F388.6Hz
