  • DS18 PRO-X6.4M 6-1/2" Professional Midrange Speaker 4 Ohm
CLEARANCE DS18 PRO-X6.4M 6-1/2" Professional Midrange Speaker 4 Ohm
DS18Part # 294-8036
Model: PRO-X6.4M
The PRO-X6.4M 6-1/2" pro midrange speaker from DS18 is designed to bring concert level output capabilities to the car audio market. A low mass paper cone and powerful motor gives the PRO-X6.4M great efficiency and the ability to hit extreme sound pressure levels. This is a great choice for filling in the midbass and midrange frequencies in any high SPL sound systems.
  • Paper cone with excellent damping properties produces realistic and detailed midrange response
  • Low mass and powerful motor to deliver high efficiency and dynamic output
  • Huge ferrite magnet ensures low power compression even after long listening sessions
  • 1-1/2" high temperature voice coil handles 225 watts RMS for extreme SPL
  • Less than 2-1/2" mounting depth allows installation into tight locations
CLEARANCE $45.95
Only 1 In Stock
We'll send you an email when DS18 PRO-X6.4M 6-1/2" Professional Midrange Speaker 4 Ohm is back in stock or available for preorder.
Order in the next 2 hr 38 min to ship today. Details
Built for clean and realistic midrange at maximum SPL, DS18's PRO-X6.4M 6-1/2" pro midrange driver can deliver concert level output with audiophile quality sound. The lightweight non-pressed paper cone and copper coated aluminum voice coil wire keeps moving mass low for dynamic response. That low mass combined with a powerful motor ensure high efficiency and excellent control. With a massive ferrite magnet and 1.5" high temperature voice coil former, the PRO-X6.4M can take up to 225 watts RMS continuously with minimal power compression. This driver will be an excellent addition to high output sound systems built to blow away the competition.
During the focused R&D period of perfecting thier PRO-EXL line, DS18 identified the opportunity to spawn off another line since there was a division amongst competition and concert audiophiles. Therefore, DS18 created the PRO audio line, which features a wide variety of midranges that produce concert-like sounds that will knock the wind out of you!
BrandDS18
ModelPRO-X6.4M
Part Number294-8036
UPC810005182997
Weight4.9
Nominal Diameter6-1/2"
Power Handling (RMS)225 Watts
Power Handling (MAX)450 Watts
Impedance4Ω
Frequency Response90 to 10,000Hz
Sensitivity92dB 2.83V/1m
Voice Coil Diameter1.5"
Magnet Weight30oz.
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Baffle Cutout Diameter5.7"
Depth2.44"
Sealed Volume0.25ft³
Sealed F3134.7Hz
Vented Volume0.4ft³
Vented F386Hz
