  • DS18 PRO-DRN2 2" Professional Neodymium Compression Driver 8 Ohm 4-Bolt
CLEARANCE DS18 PRO-DRN2 2" Professional Neodymium Compression Driver 8 Ohm 4-Bolt
DS18Part # 294-8136
Model: PRO-DRN2
DS18's neodymium powered Pro-DRN2 2" titanium compression driver is bound to make your ears happy. This driver has an impedance of 8 ohms and handles a whopping 340 watts RMS. With a high sensitivity of 106 dB, it will get extremely loud, even on moderately powered systems. Frequency response is 630 Hz to 18,000 Hz so this high intensity driver will fill all of your midrange and high frequency needs. The 3" titanium diaphragm will ensure long lasting use with recommended power.
  • Compact but powerful neodymium for low distortion and accurate response
  • Lightweight 3" titanium diaphragm produces incredible detail and excellent high frequency output
  • 106 dB sensitivity with 340 watts RMS power handling allow amazing output capability
  • 630 to 18,000 Hz frequency response for a seamless transition from midrange to high frequencies
  • 2" exit with standard 4-bolt mount is compatible with many popular horns
We'll send you an email when DS18 PRO-DRN2 2" Professional Neodymium Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Capable of producing enough output to keep up with the highest SPL systems, the Pro-DRN2 2" titanium compression driver from DS18 uses a powerful neodymium motor to deliver incredible sound quality and reliability. This high power driver uses a large but lightweight 3" diameter titanium diaphragm and voice coil to handle 340 watts RMS while producing natural response with detail and accuracy. Driving the diaphragm is a powerful neodymium motor that creates enough force for 106 dB sensitivity with excellent control and dynamics. This extreme construction gives the Pro-DRN2 what it takes to produce unmatched sound pressure levels.
Specifications: • Power handling: 340 watts RMS, 680 watts max • VCdia: 3" • Impedance: 8 ohms • Frequency response: 630-18,000 Hz • Sensitivity: 106 dB 1W/1m • Mount: 4-Bolt • Dimensions: 4.88" dia. x 2.36" depth.
BrandDS18
ModelPRO-DRN2
Part Number294-8136
UPC810005183833
Weight5.1
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)340 Watts
