  • DS18 EXL-SQ6.9 6"x9" Fiberglass Cone 2-Way Coaxial Speaker Pair 3 Ohm
CLEARANCE DS18 EXL-SQ6.9 6"x9" Fiberglass Cone 2-Way Coaxial Speaker Pair 3 Ohm
DS18Part # 294-8030
Model: EXL-SQ6.9
The DS18 EXL-SQ6.9 6" x 9" Fiberglass 2-way coaxial speaker pair is a great drop-in upgrade for your vehicle's lackluster factory speakers. With fiberglass woofers, and PEI dome tweeters this full-range coaxial speaker will deliver a balanced sound with amazing detail.
  • 6" x 9" Glass fiber cone woofer is durable and long lasting
  • 1.14" (29 mm) PEI dome tweeter designed for durability
  • Standard size for an easy drop-in installation in many factory mounting locations
  • Included grills offer protection with a modern look
  • High performance audio for an exceptional value
CLEARANCE $239.95
4 In Stock
We'll send you an email when DS18 EXL-SQ6.9 6"x9" Fiberglass Cone 2-Way Coaxial Speaker Pair 3 Ohm is back in stock or available for preorder.
The DS18 EXL-SQ6.9 6" x 9" Fiberglass 2-way coaxial speaker pair delivers 560 watts of powerful audio. The 6"x9" Fiberglass woofer driven by a 1.3" BASV voice coil and the 1.14" PEI dome tweeter are designed to be durable and long lasting. With standard size mounting points, the EXL-X6.9 speaker is a direct drop-in upgrade for many vehicles. You can expect clarity, detail, durability, and output that is unmatched by other speakers in this price range.
Note: Grills, speaker wire, and mounting hardware included
Type: 6" x 9" 2-way full range
Woofer: 6" x 9" fiberglass cone
Tweeter: 1.14" (29 mm) PEI dome tweeter
Power handling: 160 watts RMS (560 watts max)
Frequency response: 55 Hz-22 kHz
Sensitivity: 90 dB 1W/1m
Impedance: 3 ohm
Voice coil (woofer): 1.3"
Basket structure (woofer): Diecast
BrandDS18
ModelEXL-SQ6.9
Part Number294-8030
UPC095225337611
Unit of MeasurePairs
Weight8.75
Speaker Size6"
Speaker Type2-Way
Power Handling (RMS)160 Watts
