  • DJ/MC Auto-Ducking Announcement Controller Bundle for 3-Ch Silent Disco Systems
CLEARANCE DJ/MC Auto-Ducking Announcement Controller Bundle for 3-Ch Silent Disco Systems
Parts ExpressPart # 233-357
Model: DJ/MC
The 3-channel Silent Disco DJ/MC Auto-Ducking Announcement Controller Bundle allows for you to use four inputs and four outputs with the ability to use the two mic inputs to make announcements across all zone outputs. Simply connect your input source to the Rolls RM64 and assign each input a separate output zone. Take the zone outputs and connect them to the silent disco transmitter via the included adapters. This bundle is great for DJs, MCs, mobile entertainers, museums, conferences, or any application that require multiple inputs and outputs with the need for announcements over each source.
  • Four input, four zone line mixer with two mic inputs that allow each silent disco transmitter to have its own source but the ability to make announcements across all transmitters
  • Two microphones inputs with trim control and four RCA source inputs
  • Four balanced XLR zone outputs with XLR to RCA adapter and RCA Y adapter for connecting to Silent Disco Transmitters
  • Includes all adapters needed to connect the mixer to transmitters
CLEARANCE $286.98
MSRP: $286.99
Save $0.01 (0%)
Out of Stock
Estimated back in stock 1/2/2026
The Rolls RM64 four zone mixer combines two paging microphones with up to four line level source inputs. Each input is selectable to output to any combination of four zone outputs.
The outputs on the RM64 are all balanced XLR connectors, and a 1/4" remote volume jack provides each zone with the means for external volume control. The microphone inputs feature automatic ducking for easy paging. The RM64 is the ideal solution for banquet rooms, offices, restaurant/night clubs, etc. AC power adapter included. Made in the USA.
The bundle includes three female XLR to RCA male adapters as well as three RCA 2 male to 1 female Y-adapters. Use the XLR to RCA adapters to connect to the RM64 outputs. The Y adapters will connect to the XLR to RCA adapter. After connecting the Y adapter to the XLR adapter, use a standard dual RCA to dual RCA cable to connect to the silent disco transmitter inputs.
Note: the signal will be summed to a mono signal when connected to the silent disco transmitter.
RM64 Specifications: •  Frequency response: 20 - 20,000 Hz ± 0 dB • Input impedance: 10k ohms balanced; 50k ohms unbalanced • Signal-to-noise ratio: >75 dB • THD: <0.3% • Dimensions: 19" x 1.75" x 6.5".
ModelDJ/MC
Part Number233-357
UPC848864062860
Weight5.88
Mixer TypeAnalog
XLR Mic Inputs< 6
