  • DB25 Male Solder Type Connector with Metalized Plastic Hood and Gold Plated Pins Kit
CLEARANCE DB25 Male Solder Type Connector with Metalized Plastic Hood and Gold Plated Pins Kit
Parts ExpressPart # 090-525
Create your own DB25 cables with this connector with hood kit. Metalized hood helps keep EMI/RFI interference out when using shielded cable.
  • Metalized plastic hood shields out EMI/RFI interference
  • Cable entry accepts up to 0.43" (11mm) O.D. for versatility
  • Gold plated pins for long lasting/quality connection
  • Perfect for making 8-channel audio snake cables
We'll send you an email when DB25 Male Solder Type Connector with Metalized Plastic Hood and Gold Plated Pins Kit is back in stock or available for preorder.
Make your own DB25 shielded cables with this connecter hood kit. Each gold plated pin ensures a quality transmission of signal to a female DB25 connector on summing mixers, computers, and other components. The metalized plastic hood continues blocking EMI/RFI interference when using shielded wire and accepts cables with outer diameter up to 0.43" (11mm).
Part Number090-525
UPC038975744759
Weight0.1
