  • Curved Speaker Cabinet Port Tubes 1-27/32" Inner Dia. x 7-1/2" Outer Length
Parts ExpressPart # 260-484
Reduce ported speaker enclosure size by using this curved flared port tube. One end has a slightly smaller diameter to fit into the 2-1/2" hole required and ends up being the equivalent of a 6" long port tube while only taking up 5" of space.
  • Curved design helps reduce overall speaker cabinet size
  • One piece design keeps its shape without any possible air leaks
  • Easy installation with a cutout diameter of 2-1/2" (64 mm) hole
Your Price: $5.98
MSRP: $12.98
Save $7.00 (54%)
We'll send you an email when Curved Speaker Cabinet Port Tubes 1-27/32" Inner Dia. x 7-1/2" Outer Length is back in stock or available for preorder.
The utilization of a curved flared port tube can significantly reduce the size of a ported speaker enclosure. This innovative design allows for a more efficient use of space without compromising on sound quality.
One end of the port tube has a slightly smaller diameter to fit into the required 2-1/2" hole. However, this does not limit its functionality. Crafted with precision, it features a unique curved design that significantly reduces air-flow noises and friction losses. In fact, the end result is quite impressive - despite taking up only 5" of space, the curved flared port tube provides the equivalent performance of a traditional 9" long port tube.
So, why settle for a larger enclosure when you can maximize efficiency with a curved flared port tube? Embrace this technology and unleash the full potential of your speakers, all while saving valuable space.
Specifications: • Outer curved length: 7-1/2" • Outer under curved length: 4" • Tube outer diameter without flares: 2-7/32" • Largest outer diameter with flare: 2-3/4" (70 mm) • Hole size needed: 2-1/2" (64 mm) • Tube inner diameter: 2" (47 mm).
Part Number260-484
UPC848864075884
Weight0.2
