  • Cooling Fan Filter Assembly 120 x 120mm
CLEARANCE Cooling Fan Filter Assembly 120 x 120mm
Parts ExpressPart # 250-072
Keep dust and debris from clogging your cooling fan and shortening the life of your project or components. A two-piece plastic frame enables the filter assembly to be taken apart easily to clean or replace the filter media. This filter assembly fits 120 mm x 120 mm fans.
  • Plastic fan grill keeps fingers from pushing the filter into the fan
CLEARANCE $1.09
Save $1.90 (64%)
31 In Stock
We'll send you an email when Cooling Fan Filter Assembly 120 x 120mm is back in stock or available for preorder.
Order in the next 2 hr 12 min to ship today. Details
Keep dust and debris from clogging your cooling fan and shortening the life of your project or components. A two-piece plastic frame enables the filter assembly to be taken apart easily to clean or replace the filter media. This filter assembly fits 120 mm x 120 mm fans. The plastic inner frame is 121.35 mm x 121.35 mm and has four 5 mm screw holes 105 mm to center apart. The filters outer frame is 125 mm x 125 mm and has a total thickness of 10 mm when assembled together.
Part Number250-072
UPC848864007427
Weight0.1
Bearing TypeN/A
Operating VoltageN/AV
Size120
