  • Cooling Fan 45 Degree Power Cord 6 ft.
Parts ExpressPart # 250-076
2 Questions, 14 Answers or
Designed specifically to fit AC power cooling fans with blade terminal connections. Why solder to the fan terminals when you can easily connect a fan power cord. Angled fan connector takes up less space and reduces the chance the connector will accidently be bumped off. Works for single fan configuration.
  • High quality 18 gauge, 300V, 221° F VW-1 rated wire meets most AC fan requirements
  • UL listed for safety
Your Price: $4.98
MSRP: $4.99
Save $0.01 (0%)
Quantity:Qty: 1-9 $4.98/ea
Quantity:Qty: 10+ $4.48/ea
73 In Stock
We'll send you an email when Cooling Fan 45 Degree Power Cord 6 ft. is back in stock or available for preorder.
Designed specifically to fit AC power cooling fans with blade terminal connections. Why solder to the fan terminals when you can easily connect a fan power cord. Angled fan connector takes up less space and reduces the chance the connector will accidently be bumped off. High quality 18 gauge, 300V, 221° F VW-1 rated wire meets most AC fan requirements. Works for single fan configuration.
Part Number250-076
UPC848864007441
Weight0.15
