  • Muffin Style Axial Cooling Fan 120 VAC 80 x 80 x 25mm 18 CFM
Parts ExpressPart # 250-052
110 VAC cooling fan 80 x 80 x 25 mm.
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
  • Low noise
Your Price: $7.49
MSRP: $8.99
Save $1.50 (17%)
42 In Stock
We'll send you an email when Muffin Style Axial Cooling Fan 120 VAC 80 x 80 x 25mm 18 CFM is back in stock or available for preorder.
Order in the next 0 hr 43 min to ship today. Details
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. These economical cooling fans are a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. These fans come with un-terminated lead wires.
Specifications: • Operating voltage: 110 VAC • Power: 12 watts • Speed: 2450 RPM • Airflow: 18 CFM • Noise: 29 dB • Dimensions(mm): 80 W x 80 H x 25 D.
Part Number250-052
UPC848864007328
Weight0.55
Bearing TypeSleeve Bearing
Operating Voltage110~120 VACV
Size80
