  • Muffin Style Axial Cooling Fan 120 VAC 120 x 120 x 38mm 100 CFM
Parts ExpressPart # 250-058
110 VAC cooling fan 120 x 120 x 38 mm.
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
  • Low noise
Your Price: $9.79
MSRP: $10.99
Save $1.20 (11%)
278 In Stock
We'll send you an email when Muffin Style Axial Cooling Fan 120 VAC 120 x 120 x 38mm 100 CFM is back in stock or available for preorder.
Order in the next 15 hr 31 min to ship today. Details
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. These economical cooling fans are a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. These fans come with terminals to mate with a fan power cord.
Specifications: • Operating voltage: 110 VAC • Power: 23 watts • Speed: 2800 RPM • Airflow: 100 CFM • Noise: 46 dB • Dimensions(mm): 120 W x 120 H x 38 D.
Part Number250-058
UPC848864007359
Weight1.05
Bearing TypeSleeve Bearing
Operating Voltage110~120 VACV
Size120
