  • Cooling Fan 12 VDC 120 x 120 x 25mm 83 CFM
Parts ExpressPart # 250-062
12 VDC cooling fan 120 x 120 x 25 mm.
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
  • Low noise
Your Price: $8.49
We'll send you an email when Cooling Fan 12 VDC 120 x 120 x 25mm 83 CFM is back in stock or available for preorder.
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. These economical cooling fans are a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. These fans come with 3-pin header plug that can be removed for custom applications.
Specifications: • Operating voltage: 12 VDC • Power: 3 watts • Speed: 2400 RPM • Airflow: 83 CFM • Noise: 45 dB • Current draw: 0.25A Dimensions(mm): 120 W x 120 H x 25 D.
Part Number250-062
UPC848864007373
Weight0.243
Bearing TypeSleeve Bearing
Operating Voltage12 VDCV
Size120
